On Mon, Nov 24, 2014 at 1:45 PM, Mickael Beaufils <
mickael.beaufils@anonymised.com> wrote:
Hello,
I am facing some trouble with GetFeatureInfo responses from GeoServer
(2.6).
In fact as far as charset is not defined for GetFeatureInfo responses , my
GIS desktop applications (QGIS 2.6 and MapInfo 11.0) don’t manage well
special characters. Whereas It works well with QGIS 1.8.
Then I added <meta http-equiv="content-type" content="text/html; charset=UTF-8"></meta> in the header of my GetFeatureInfo template, so it solved the problem with text/html responses but not for text/plain responses.
Is there a solution to specify charset for GetFeatureInfo text/plain
responses?
We have a solution for other types of responses on the development series,
it makes the charset http header added for
all text/xml based responses.
However, it has not been backported to the stable series (2.6.x) yet, the
change is not small, a vote would probably be required
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
