[Geoserver-users] GetFeatureInfo to Geoserver
Hello all, I have a very simple client application that I am using to host a few vector layers. I used to be able to, prior to Geoserver 1.7.5, be able to specify multiple layers (features) in the QUERY_LAYERS parameter. Now when I add even more than one to the query I get back:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
Which is very vauge, and this is what I get in the logs:
org.vfny.geoserver.wms.WmsException
at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.execute(AbstractFeatureInfoResponse.java:410)
at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:145)
at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:94)
at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.execute(GetFeatureInfoResponse.java:97)
at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:699)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:265)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:275)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:124)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:174)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:249)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:149)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.lang.NullPointerException
at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.getActiveRules(AbstractFeatureInfoResponse.java:438)
at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.execute(AbstractFeatureInfoResponse.java:245)
… 55 more
This is my query that fails:
http://localhost:8000/geoserver/wms?REQUEST=GetFeatureInfo&EXCEPTIONS=application%2Fvnd.ogc.se_xml&BBOX=-77.882455%2C39.066564%2C-76.902023%2C39.874194&X=444&Y=174&INFO_FORMAT=text%2Fhtml&QUERY_LAYERS=shape%3Amd_frederick_parcels_Parcels_Dist%2Cshape%3Amd_frederick_schools_Schools&FEATURE_COUNT=50&Layers=shape%3Amd_frederick_parcels_Parcels_Dist&Styles=&Srs=EPSG%3A4326&WIDTH=800&HEIGHT=659&format=image%2Fpng
Thanks!
web http://www.hyxspace.com
aim hyx1138
There is something going on with the styles. A valid GetFeatureInfo request requires the styles=... parameter, but I see you added it...
the only other way I can see things go wrong is that one of the layers
your requesting has no default style associated to it?
Andrea Aime
OpenGeo - http://opengeo.org
I checked both and they do have a default style assigned in the feature type. These are styles with some special icons specified in the sld but they come up independently in their own map preview demos. I did try changing the one with the icons back to just ‘point’ and it still failed with an Internal Server Error.
There is something going on with the styles. A valid GetFeatureInfo request requires the styles=… parameter, but I see you added it…
Andrea Aime
aim hyx1138
I checked both and they do have a default style assigned in the feature type. These are styles with some special icons specified in the sld but they come up independently in their own map preview demos. I did try changing the one with the icons back to just 'point' and it still failed with an Internal Server Error.
Do styles have anything else specific? Scale dependencies maybe?
http://gridlock.openplans.org/geoserver/1.7.x/
Can you try out with a nightly build and see what error you get back?
Andrea Aime
No this is the same problem I found - you need to name all the query
layers in the layers parameter or GeoServer throws an unhelpful error.
Ian
Ian Turton
Sent from State College, Pennsylvania, United States
Aah, duh, right, I forgot what the exact cause was, thanks for reminding
me. Yeah, the query_layers argument should be a subset of the layers
one
Andrea Aime
Yup, I checked out the new build and got a much better error message:
QUERY_LAYERS contains layers not cited in LAYERS. It should be a proper subset of those instead
Thanks, for your help guys!
one
Andrea Aime
aim hyx1138
My simple application gives me the following error
"QUERY_LAYERS contains layers not cited in LAYERS. It should be a proper
subset of those instead". Yes, i do not want to query all layers so under
the 'layers' parameter under 'get feature info' i skipped adding a layer.
What should be the correct approach? How can i get rid of the error message?
Thanks
View this message in context: http://osgeo-org.1560.x6.nabble.com/GetFeatureInfo-to-Geoserver-tp3802214p5147541.html
