[Geoserver-users] getFeatures by BBOX
Hello!
I want to get all fetaures in a layer that is within a BBOX, this is the url I’m using:
http://webmap.smhi.se:58080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=smhi:halka_time1&propertyName=typ,skapad&BBOX=650909.1813958837,5427024.1381324865,2305434.503697643,7918123.2622701675
If I put this url directly in the browser it only returns a empty featuretype-tag, no errors. But if I run the same url in Geoservers demo-request I get this error:
org.xmlpull.v1.XmlPullParserException: only whitespace content allowed before start tag and not h (position: START_DOCUMENT seen h… @1:1) only whitespace content allowed before start tag and not h (position: START_DOCUMENT seen h… @1:1)
None of the behaviors is the result I want to get back… There are features within this bounding-box, if I open the same layer in “Map preview” the features is shown correctly and the bounding box is the same as I use in the url above.
Do anyone know what the problem might be?
Best regards**:**
Mårten Swärd
Systemutvecklare/Webbutvecklare, ITs
SMHI, Sveriges Meteorologiska och Hydrologiska Institut
Tel: +46 11 495 8469
Swärd Mårten ha scritto:
Hello!
_http://webmap.smhi.se:58080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=smhi:halka_time1&propertyName=typ,skapad&BBOX=650909.1813958837,5427024.1381324865,2305434.503697643,7918123.2622701675_ <http://webmap.smhi.se:58080/geoserver/wfs?request=GetFeature&version=1.1.0&typeName=smhi:halka_time1&propertyName=typ,skapad&BBOX=650909.1813958837,5427024.1381324865,2305434.503697643,7918123.2622701675&gt;
Emtpy feature type tag? Maybe emtpy feature collection one?
If so it means there are no features in the bbox you've
requested. Try running the same request without
the bbox filter.
*org.xmlpull.v1.XmlPullParserException: only whitespace content allowed before start tag and not h (position: START_DOCUMENT seen h... @1:1) only whitespace content allowed before start tag and not h (position: START_DOCUMENT seen h... @1:1)*****
That's because you pasted it in the box reserved for the POST
content, instead of pasting it into the the url field.
None of the behaviors is the result I want to get back.. There are features within this bounding-box, if I open the same layer in “Map preview” the features is shown correctly and the bounding box is the same as I use in the url above.
Hmm... really really sure? :slight_smile:
Ah, which version of geoserver are you using?
Hello Andrea.
Thanks for your answer!
the bbox filter.
Yes, it's an empty fetaure collection tag. If I try to run it without bbox then I get the result that I expected. But I'm 100% sure that I'm using the same BBOX as in the "Map Preview" application and it should return some fetaures that I know is within the BBOX and that is shows in the "Map Prebiew" application.
The demo example (Sample Request->WFS_getFeatureBBOX.url) that comes with the installation of geoserver also returns an empty feature collection, I don't know if is should do that but my guess is that it supposed to return something..
Yepp, I'm realy realy realy sure.. Almost.. =)
We are using geoserver 1.6.0-RC3
Thanks again!
Regards: Mårten
Mvh:
Mårten Swärd
-----Ursprungligt meddelande-----
Från: Andrea Aime [mailto:aaime@anonymised.com]
Skickat: den 7 februari 2008 12:11
Till: Swärd Mårten
Kopia: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] getFeatures by BBOX
Hello!
url I'm using:
featuretype-tag,
the bbox filter.
features within this bounding-box, if I open the same layer in "Map
preview" the features is shown correctly and the bounding box is the
