Hello.
If a layer has a alias (the one you can set in FeatureType in the administration-view) then some strange things happens when I try to make a GetFetureInfo-request…
The layer with aliases only returns the field names and not the data, if I remove the alias then everything works fine.
The datastore is a Postgres/PosGIS database, and the Geoserver version I’m using is 1.7.3.
Is this a bug or should I keep trying? J
Best regards, Mårten
JIRA says Justin found and fixed it for 1.7.4 , http://jira.codehaus.org/browse/GEOS-2820
-Arne
Swärd Mårten wrote:
Hello.
If a layer has a alias (the one you can set in FeatureType in the administration-view) then some strange things happens when I try to make a GetFetureInfo-request..
The datastore is a Postgres/PosGIS database, and the Geoserver version I'm using is 1.7.3.
Register Now & Save for Velocity, the Web Performance & Operations Conference from O'Reilly Media. Velocity features a full day of expert-led, hands-on workshops and two days of sessions from industry leaders in dedicated Performance & Operations tracks. Use code vel09scf and Save an extra 15% before 5/3. http://p.sf.net/sfu/velocityconf
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Great! Thanks!
Mvh:
Mårten Swärd
Systemutvecklare/Webbutvecklare, ITs
SMHI, Sveriges Meteorologiska och Hydrologiska Institut
Tel: +46 11 495 8469
-----Ursprungligt meddelande-----
Från: Arne Kepp [mailto:ak@anonymised.com]
Skickat: den 4 maj 2009 11:01
Till: Swärd Mårten
Kopia: geoserver-users@lists.sourceforge.net
Ämne: Re: [Geoserver-users] GetFetaureInfo-problem
-Arne
Swärd Mårten wrote:
Hello.
Arne Kepp
