Hi Justin
thanks for the answer.
regards
Stefan
Von: Justin Deoliveira [mailto:jdeolive@anonymised.com]
Gesendet am: Montag, 5. Mai 2008 16:08
An: Ziegler Stefan
Cc: geoserver-users
Betreff: Re: [Geoserver-users] GetLegendGraphic and styles without
filters
Hi Stefan,
I believe this is the intended behavior because your style only has a
single rule. If you add another rule to it, you should see the thematic
legend kick in.
-Justin
Ziegler Stefan wrote:
Hi
I’m requesting a legend with the following line:
http://srsofaioi12288:8080/geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=40&HEIGHT=20&STYLE=av_meta_waiting&LAYER=topp:geo_gemeinden_vThe resulting image is a green rectangle but there is no text/label at
<?xml version="1.0" encoding="iso-8859-1"?>
the rectangle. The sld looks like this:
Infogrips
Infogrips
#66FF00
0.5
If I use some filters than the labes appear. Is this the correct
behaviour or a bug or not a correct sld? (I’m using Geoserver 1.6.3).regards
StefanMit freundlichem Gruss
Stefan Ziegler
Leiter AufsichtKanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
Rötistrasse 4
4501 Solothurn
Telefon 032 627 75 96
Telefax 032 627 75 98
stefan.ziegler@anonymised.com
http://www.so.ch!DSPAM:4007,481b1d5f99021439371379!
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone!DSPAM:4007,481b1d5f99021439371379!
Geoserver-users mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-users!DSPAM:4007,481b1d5f99021439371379!
Justin Deoliveira
The Open Planning Project
