[Geoserver-users] GetLegendGraphic fails if SLD uses filter function round
Hi list,
I wonder if anyone else has seen something like this.
I have a PostGIS table defined basically as
CREATE TABLE vdline
ogc_fid serial NOT NULL,
hast_gener character varying,
kode_hast0 character varying,
hast_lokal double precision,
hast_gaeld double precision,
hast_anbef double precision,
hast_var_h character varying,
geometri geometry(MultiLineString),
CONSTRAINT vdline_pkey PRIMARY KEY (ogc_fid)
WITH (
OIDS=FALSE
I publish it through GeoServer 2.9.1, using a style looking basically like this:
<?xml version="1.0" encoding="ISO-8859-1"?>
vdline
Hastighedsgrænser
Visualisering af hastighedsgrænsedata
Skiltet hastighed 40
Skiltet hastighed 40 km/t
Skiltet hastighed (hast_lokal) 40 km/t. Etiket viser gældende hastighed (hast_gaeld)
ogc:Filter
ogc:PropertyIsEqualTo
ogc:PropertyNamehast_lokal</ogc:PropertyName>
ogc:Literal40</ogc:Literal>
</ogc:PropertyIsEqualTo>
</ogc:Filter>
#0000ff
1
<ogc:Function name=“round”>ogc:PropertyNamehast_gaeld</ogc:PropertyName></ogc:Function>
10
Arial
#0000aa
0
ogc:Literal1</ogc:Literal>
#f4faf6
#0000aa
50
true
true
true
The complete SLD contains multiple s for various values of hast_lokal.
If I make a GetLegendGraphic-request like
http://hostname/workspace/wms?service=WMS&version=1.1.0&request=GetLegendGraphic&layer=vdline&format=image/png
I get the error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
java.lang.IllegalArgumentException: Filter Function problem for function round argument #0 - expected type float
If I modify the SLD, specifically the , removing the <ogc:Function name=”round”>, so that it becomes
I get a nice legend. Is that a bug?
/julian
Nope it isn’t a bug - the error is quite clear
You are passing something that isn’t a number into the round function - you’ll either need to check your attributes or add a check to the SLD to limit the input to numbers (probably with an if_then_else and a regexp)
On 15 February 2017 at 14:51, Julian Hollingbery <julian@…5218…> wrote:
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
Geoserver-users mailing list
Geoserver-users@…382…sourceforge.net
Ian Turton
Two things I’d like to note:
  1. I can make GetMap and GetFeatureInfo requests just fine over the entire area covered by the dataset. Only GetLegendGraphic fails.
  2. As you can see from the table definition, the parameter to the function is a double. I’ll admit that there are NULL values in a few rows, but why should that prevent GeoServer from generating a legend?
Fra: Ian Turton [mailto:ijturton@…84…]
Sendt: 15. februar 2017 16:07
Til: Julian Hollingbery <julian@…5218…>
Emne: Re: [Geoserver-users] GetLegendGraphic fails if SLD uses filter function round
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Ian Turton
Then you’ll need something like
<ogc:Function name=“if_then_else”><ogc:Function name=“isNull”>ogc:PropertyNamehast_gaeld</ogc:PropertyName></ogc:Function>ogc:Literal0.0</ogc:Literal>,ogc:PropertyNamehast_gaeld</ogc:PropertyName></ogc:Function>
</ogc:Function>
Cc: geoserver-users@…382…sourceforge.net
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Ian Turton
Ian Turton
Hi Ian,
it might, or might not… to build legend graphics we create a sample features with all default
values for the data types of the feature… it might be that map rendering works,
but legend graphic fails
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Geoserver-users@…454…rge.net
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Thanks, that did the trick J
Still seem a bit odd that GetLegendGraphic is more brittle than GetMap…
</ogc:Function>
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Ian Turton
Ian Turton
Andrea,
That seems to indicate that our fake feature does contain a NULL - may be because the attribute allows NULLs?
Infact I think I’ve been bitten by this before - assuming it is using DataUtilities.defaultValue which does return Null if it can get away with it
I used a method like:
private SimpleFeature generateDefaultFeature(SimpleFeatureType schema) {
SimpleFeature defaultFeature = DataUtilities.template(schema, schema.getTypeName());
// we have to do this as our nullable attributes will be null if not
for (Property prop : defaultFeature.getProperties()) {
Object defaultValue = DataUtilities.defaultValue(prop.getType().getBinding());
defaultFeature.setAttribute(prop.getName(), defaultValue);
return defaultFeature;
to avoid this issue.
Ian
Sendt: 15. februar 2017 16:22
</ogc:Function>
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Ian Turton
Ian Turton
Ian Turton
Hi Ian,
it depends on whether it has a reference layer or not in the request, it might go into one of these:
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/legendgraphic/BufferedImageLegendGraphicBuilder.java#L759
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/legendgraphic/BufferedImageLegendGraphicBuilder.java#L780
https://github.com/geoserver/geoserver/blob/master/src/wms/src/main/java/org/geoserver/wms/legendgraphic/BufferedImageLegendGraphicBuilder.java#L856
Not sure what they do, legend graphics generation is one of the places that I’m not really familiar with :-p
On Wed, Feb 15, 2017 at 4:56 PM, Ian Turton <ijturton@…84…> wrote:
Andrea,
Ian
Cc: geoserver-users@…454…rge.net
</ogc:Function>
Hi list,
CREATE TABLE vdline
WITH (
OIDS=FALSE
vdline
Hastighedsgrænser
ogc:Filter
</ogc:Filter>
#0000ff
1
10
Arial
#0000aa
0
#f4faf6
#0000aa
50
true
true
true
I get the error:
/julian
Ian Turton
Ian Turton
Ian Turton
Ing. Andrea Aime
@geowolf
Technical Lead
