Pere,
Yes it is possible. I use it at http://data.aad.gov.au/aadc/symbology
however I pass the URL of a generated SLD file instead of using SLD_BODY
because of the length restrictions of URLs. It should still work the
same though.
Miles Jordan
Applications Developer
The Australian Antarctic Division
> -----Original Message-----
> From: pere roca
> I suspect it's not possible, but...
> I want users to generate the symbology dynamically (user
> classifies point data to visualize and applies rules of
> symbology). It modifies the Web Map Context file ( we create
> SLD_BODY).
> Is possible to user GetLegendGraphic to retrieve the legend?
> thanks,
> Pere
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-users mailing list Geoserver-users@lists.sourceforge.net
___________________________________________________________________________
Australian Antarctic Division - Commonwealth of Australia
IMPORTANT: This transmission is intended for the addressee only. If you are not the
intended recipient, you are notified that use or dissemination of this communication is
strictly prohibited by Commonwealth law. If you have received this transmission in error,
please notify the sender immediately by e-mail or by telephoning +61 3 6232 3209 and
DELETE the message.
Visit our web site at http://www.antarctica.gov.au/
thanks Miles,
I've seen in the Demo of Geoserver a GetLegendGraphic request of SLD_BODY.
The problem is how to generate the GetLegendGraphic-SLD_BODY URL request.
My webapplication (using mapBuilder) takes SLD_BODY directly from the Web
Map Context file. Any idea to automatically "translate" the SLD in the WMC
to the URL of the GetLegendGraphic-SLD_BODY?
I'm thinking also about dynamically manipulating the SLD (then,
GetLegendGraphic is much easier). Do you think it should increase the
performace? what's the max length for the SLD_BODY request?
cheers,
Pere
Miles Jordan wrote:
Pere,
same though.
Miles Jordan
> From: pere roca
> SLD_BODY).
> thanks,
> Pere
are not the
communication is
6232 3209 and
DELETE the message.
View this message in context: http://www.nabble.com/Re%3A-getlegendgraphic-from-SLD_BODY---Sec%3DUnclassified--tp14937313p15001448.html
