Another spec that does odd things.
Looking at the specs, WMS 1.1.0 doesn’t appear to have an opinion on duplicate parameters:
Parameters in a request may be specified in any order.
An OGC Web Service shall be prepared to encounter parameters that are not part of this
specification. In terms of producing results per this specification, an OGC Web Service
shall not require such parameters.
But WMS 1.3.0 is clearer:
When request parameters are duplicated with conflicting values, the response from the server may be undefined.
This International Standard does not mandate which of the duplicated values sent by the client are to be used by
the server.
However, these aren’t conflicting values, they’re identical values. Also, the second line strongly implies (to me anyway), that the WMS should still work with duplicate values, otherwise why specify that the server gets to choose which of the parameters to use? And that the server can perform “undefined” behaviour if they’re conflicting?
Just a thought.
Jonathan
On 7 February 2013 13:04, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Thu, Feb 7, 2013 at 1:45 PM, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Its a bug, but not the obvious one.
Your URL has two “format=image/png” in it. Remove either one and it works fine. Leave them both in and I get:
“Invalid graphic format: [Ljava.lang.String;@d9275d”
With more testing it seems that that some fail in those circumstances (two “&layer” fails too) and some don’t. I’ll report it on JIRA as its inconsistent.
This is the result of adding support for WCS 2.0 in the general KVP parser, in WCS having two times the same parameter has
a meaning of its own, they cannot be ignored.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
