Is it possible to formulate a GetMap rquest to build a map of polygons based on a bounding box as well as an feature/attribute value? So, image a Postgis table that contains all the buildings in a metropolitan area. A column in this table indicates the classification of each building (polygon). Could I somehow pass this information as a filter to the GetMap request so that I only retrieve polygons for a building classification?
__________________________________
Jeremy Nix
Senior Application Developer
Southwest Financial Services, Ltd.
(513) 621-6699
Hi Jeremy,
Yup, should be possible with an And filter. Something like this:
<Filter>
<And>
<BBOX>
<gml:Box><gml:coordinates>...</gml:coordinates></gml:Box>
</BBOX>
<PropertyIsEqualTo>
<PropertyName>...</PropertyName>
<Literal>...</Literal>
</PropertyIsEqualTo>
</And>
</Filter>
-Justin
classification?
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
Yes you can add whatever filter you want adding either FILTER or CQL_FILTER to your request, just as if it was a WFS GetFeature request
using the GET protocol. More information here:
http://docs.codehaus.org/display/GEOSDOC/WMS+vendor+parameters
(and you should be able to find some samples in the sample requests
shipping with GeoServer as well).
