[Geoserver-users] Getting an error when trying to save imagemosaic store
I'm trying to create a imagemosaic store of radar mosaics using postgres for feature info. I'm getting the below error when trying to save the store. I have a datastore.properties, RADAR_NATIONAL_BREF.properties files in the data directory. I created a layer from the failed store (allowed me to save but still had the error), the feature info (validtime, location (filename), region, type are all fine. Just no image. I saw a post in Sept 25 2013 similar but no resolution other than update for Linux (I'm on windows). I am running GeoServer 2.4.4. any help would be greatly appreciated. thanks. Below is the error message.
Failed to create reader from file://e:\earl-web\radar\geoserver\RADAR_NATIONAL_BREF and hints Hints: FILTER_FACTORY = FilterFactoryImpl STYLE_FACTORY = StyleFactoryImpl FEATURE_FACTORY = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com FORCE_AXIS_ORDER_HONORING = http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0] LENIENT_DATUM_SHIFT = true COMPARISON_TOLERANCE = 1.0E-9
A couple of questions to gather some more info:
Which format of data are you mosaicking?
Could you please report the content of RADAR_NATIONAL_BREF.properties?
Does that file it have been automatically created on configuration or did you set it by yourself?
Please, let us know.
Best Regards,
Daniele
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com> wrote:
I’m trying to create a imagemosaic store of radar mosaics using postgres for feature info. I’m getting the below error when trying to save the store. I have a datastore.properties, RADAR_NATIONAL_BREF.properties files in the data directory. I created a layer from the failed store (allowed me to save but still had the error), the feature info (validtime, location (filename), region, type are all fine. Just no image. I saw a post in Sept 25 2013 similar but no resolution other than update for Linux (I’m on windows). I am running GeoServer 2.4.4. any help would be greatly appreciated. thanks. Below is the error message.
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
