Yes, pretty simple image, here is the content:
0.01
0.0
0.0
-0.01
-125.0
50.0
---- Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Do you also have world files for those images?Daniele
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.Ing. Daniele Romagnoli
Senior Software EngineerGeoSolutions S.A.S.
Via Poggio alle Viti 1187
fax: +39 0584 1660272http://www.geo-solutions.it
http://twitter.com/geosolutions_it-------------------------------------------------------
On Mon, Feb 24, 2014 at 4:00 PM, <ebarker111@anonymised.com> wrote:
> Sorry about that.
> There are X number of files (I haven't worked out the purging of the db,
> etc yet). The files are named with the date time. etc
> I'll try the mosaic configuration using the mosaicking machinery.
> thanks.
> > Hi,
> > keeping the mailing list in the loop for future reference regarding
> similar
> > issues.
> > That property file will be automatically created by the mosaicking
> > machinery.
> > Could you retry the mosaic configuration without that file in the folder?
> > Not sure to fully understand: do you have a single PNG file?
> > Cheers,
> > Daniele
> more
> > information.
> > GeoSolutions S.A.S.
> > Italy
> > On Mon, Feb 24, 2014 at 3:26 PM, <ebarker111@anonymised.com> wrote:
> > > Daniele,
> > > Thanks.. the image is a png, here is the
> > > RADAR_NATIONAL_BREF.properties file content: I created the file
> manually.
> > > Levels=0.01,0.01
> > > Heterogeneous=false
> > > TimeAttribute=time
> > > AbsolutePath=false
> > > Name=RADAR_NATIONAL_BREF
> > > TypeName=RADAR_NATIONAL_BREF
> > > Caching=false
> > > ExpandToRGB=false
> > > LocationAttribute=location
> SuggestedSPI=com.sun.media.imageioimpl.plugins.png.CLibPNGImageReaderSpi
> > > LevelsNum=1
> > > > Hi,
> > > > A couple of questions to gather some more info:
> > > > Which format of data are you mosaicking?
> > > > Could you please report the content of
> RADAR_NATIONAL_BREF.properties?
> > > > Does that file it have been automatically created on configuration
> or did
> > > > you set it by yourself?
> > > > Please, let us know.
> > > > Best Regards,
> > > > Daniele
> > > more
> > > > information.
> > > > GeoSolutions S.A.S.
> > > > Italy
> > > > On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com> wrote:
> > > > > I'm trying to create a imagemosaic store of radar mosaics using
> > > postgres
> > > > > for feature info. I'm getting the below error when trying to save
> the
> > > > > store. I have a datastore.properties,
> > > files
> > > > > in the data directory. I created a layer from the failed store
> > > (allowed me
> > > > > to save but still had the error), the feature info (validtime,
> location
> > > > > (filename), region, type are all fine. Just no image. I saw a
> post in
> > > > > Sept 25 2013 similar but no resolution other than update for Linux
> > > (I'm on
> > > > > windows). I am running GeoServer 2.4.4. any help would be greatly
> > > > > appreciated. thanks. Below is the error message.
> > > > > Failed to create reader from
> > > > > file://e:\earl-web\radar\geoserver\RADAR_NATIONAL_BREF and hints
> Hints:
> > > > > FILTER_FACTORY = FilterFactoryImpl STYLE_FACTORY = StyleFactoryImpl
> > > > > FEATURE_FACTORY =
> org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com=
> http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
> > > > > EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com
> > > [Running,
> > > > > pool size = 0, active threads = 0, queued tasks = 0, completed
> tasks =
> > > 0]
> > > > > LENIENT_DATUM_SHIFT = true COMPARISON_TOLERANCE = 1.0E-9
> > > > > Managing the Performance of Cloud-Based Applications
> > > > > Take advantage of what the Cloud has to offer - Avoid Common
> Pitfalls.
> > > > > Read the Whitepaper.
> http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
> > > > > _______________________________________________
> > > > > Geoserver-users mailing list
> > > > > Geoserver-users@lists.sourceforge.net
> > > > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
