[Geoserver-users] Getting an error when trying to save imagemosaic store
Trying to create the Image Mosaic store from scratch. Getting this error trying to connect to the
Caused by: java.lang.IllegalArgumentException: java.io.IOException: Cannot find JNDI data source: java:comp/env/jdbc/postgres
  at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.<init>(GTDataStoreGranuleCatalog.java:194)
  at org.geotools.gce.imagemosaic.catalog.GranuleCatalogFactory.createGranuleCatalog(GranuleCatalogFactory.java:68)
  at org.geotools.gce.imagemosaic.CatalogManager.createGranuleCatalogFromDatastore(CatalogManager.java:163)
Three files in additional to the png and pgw files:
    datastore.properties :
SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
jndiReferenceName=java:comp/env/jdbc/postgres
host=localhost
port 5432
database=WxCasterData
schema=public
Loose\ bbox=true
Estimated\ extends=false
validate\ connections=true
Connection\ timeout=10
preparedStatements=true
indexer.properties:
TimeAttribute=time
Schema=*geom:Polygon,location:String,time:java.util.Date,
PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](ingestion)
timeregex.properties:
regex=[0-9]{8}T[0-9]{9}Z(\?!.\*[0-9]{8}T[0-9]{9}Z.\*)
---- ebarker111@anonymised.com wrote:
Yes, pretty simple image, here is the content:
0.01
0.0
0.0
-0.01
-125.0
50.0
---- Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
> Hi,
> Do you also have world files for those images?
> Daniele
> Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
> information.
> Ing. Daniele Romagnoli
> Senior Software Engineer
> GeoSolutions S.A.S.
> Via Poggio alle Viti 1187
> 55054 Massarosa (LU)
> Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> On Mon, Feb 24, 2014 at 4:00 PM, <ebarker111@anonymised.com> wrote:
> > Sorry about that.
> > There are X number of files (I haven't worked out the purging of the db,
> > etc yet). The files are named with the date time. etc
> > I'll try the mosaic configuration using the mosaicking machinery.
> > thanks.
> > > Hi,
> > > keeping the mailing list in the loop for future reference regarding
> > similar
> > > issues.
> > > That property file will be automatically created by the mosaicking
> > > machinery.
> > > Could you retry the mosaic configuration without that file in the folder?
> > > Not sure to fully understand: do you have a single PNG file?
> > > Cheers,
> > > Daniele
> > more
> > > information.
> > > GeoSolutions S.A.S.
> > > Italy
> > > On Mon, Feb 24, 2014 at 3:26 PM, <ebarker111@anonymised.com> wrote:
> > > > Daniele,
> > > > Thanks.. the image is a png, here is the
> > > > RADAR_NATIONAL_BREF.properties file content: I created the file
> > manually.
> > > > Levels=0.01,0.01
> > > > Heterogeneous=false
> > > > TimeAttribute=time
> > > > AbsolutePath=false
> > > > Name=RADAR_NATIONAL_BREF
> > > > TypeName=RADAR_NATIONAL_BREF
> > > > Caching=false
> > > > ExpandToRGB=false
> > > > LocationAttribute=location
> > SuggestedSPI=com.sun.media.imageioimpl.plugins.png.CLibPNGImageReaderSpi
> > > > LevelsNum=1
> > > > > Hi,
> > > > > A couple of questions to gather some more info:
> > > > > Which format of data are you mosaicking?
> > > > > Could you please report the content of
> > RADAR_NATIONAL_BREF.properties?
> > > > > Does that file it have been automatically created on configuration
> > or did
> > > > > you set it by yourself?
> > > > > Please, let us know.
> > > > > Best Regards,
> > > > > Daniele
> > > > more
> > > > > information.
> > > > > GeoSolutions S.A.S.
> > > > > Italy
> > > > > On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com> wrote:
> > > > > > I'm trying to create a imagemosaic store of radar mosaics using
> > > > postgres
> > > > > > for feature info. I'm getting the below error when trying to save
> > the
> > > > > > store. I have a datastore.properties,
> > > > files
> > > > > > in the data directory. I created a layer from the failed store
> > > > (allowed me
> > > > > > to save but still had the error), the feature info (validtime,
> > location
> > > > > > (filename), region, type are all fine. Just no image. I saw a
> > post in
> > > > > > Sept 25 2013 similar but no resolution other than update for Linux
> > > > (I'm on
> > > > > > windows). I am running GeoServer 2.4.4. any help would be greatly
> > > > > > appreciated. thanks. Below is the error message.
> > > > > > Failed to create reader from
> > > > > > file://e:\earl-web\radar\geoserver\RADAR_NATIONAL_BREF and hints
> > Hints:
> > > > > > FILTER_FACTORY = FilterFactoryImpl STYLE_FACTORY = StyleFactoryImpl
> > > > > > FEATURE_FACTORY =
> > org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com=
> > http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
> > > > > > EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com
> > > > [Running,
> > > > > > pool size = 0, active threads = 0, queued tasks = 0, completed
> > tasks =
> > > > 0]
> > > > > > LENIENT_DATUM_SHIFT = true COMPARISON_TOLERANCE = 1.0E-9
> > > > > > Managing the Performance of Cloud-Based Applications
> > > > > > Take advantage of what the Cloud has to offer - Avoid Common
> > Pitfalls.
> > > > > > Read the Whitepaper.
> > http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
> > > > > > _______________________________________________
> > > > > > Geoserver-users mailing list
> > > > > > Geoserver-users@lists.sourceforge.net
> > > > > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Ciao Earl,
please, find my answer inline below...
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
It looks like you are trying to access a JNDI connection pool which is
not available. Try to create a datastore directly in the UI for
GeoServer for that JNDI name to make sure is correct
and double check the config in Tomcat (or whateevr the application
server you are using is).
That said, I would not explicitly force preparedStatements to true.
Let us know how it goes.
host=localhost
port 5432
schema=public
Loose\ bbox=true
indexer.properties:
TimeAttribute=time
0.01
0.0
0.0
-0.01
-125.0
50.0
> Hi,
> Daniele
> information.
> GeoSolutions S.A.S.
> Italy
> > Sorry about that.
> > thanks.
> > > Hi,
> > similar
> > > issues.
> > > machinery.
> > > Cheers,
> > > Daniele
> > more
> > > information.
> > > GeoSolutions S.A.S.
> > > Italy
> > > > Daniele,
> > manually.
> > > > Levels=0.01,0.01
> > > > Heterogeneous=false
> > > > TimeAttribute=time
> > > > AbsolutePath=false
> > > > Caching=false
> > > > ExpandToRGB=false
> > > > LevelsNum=1
> > > > > Hi,
> > or did
> > > > > Best Regards,
> > > > > Daniele
> > > > more
> > > > > information.
> > > > > GeoSolutions S.A.S.
> > > > > Italy
> > > > postgres
> > the
> > > > files
> > > > (allowed me
> > location
> > post in
> > > > (I'm on
> > Hints:
> > > > > > FEATURE_FACTORY =
> > > > [Running,
> > tasks =
> > > > 0]
> > Pitfalls.
