[Geoserver-users] Getting an error when trying to save imagemosaic store
Cario
   thanks. But the only OS that I've seen TomCat on are Linux and SUN. I'm on a Windows box, so any instructions on setting up the connection pool from a Windows machine would be awesome.
   Earl
---- carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
Earl,
Error creating data store, check the parameters. Error message: Cannot find
> JNDI data source: java:comp/env/jdbc/WxCasterData
This is probably why you still have to configure the connection pool as
resource into your application server.
Here is a quick howto to get this working in tomcat:
http://docs.geoserver.org/stable/en/user/tutorials/tomcat-jndi/tomcat-jndi.html
Let we know if this is the case.
Carlo
> Note: I am a Meteorologist who writes applications to process and display
> various weather products (radar and satellite imagery, model graphics,
> forecaster created graphics, etc). I know enough about web hosting on my
> Windows PC to get IIS installed and running, installing php, etc., I know
> enough to get GeoServer running (I love viewing my vector graphics products
> in GeoServer that were stored in Postgres (watches, warnings, mesoscale
> discussions, convective outlooks, etc), which I appreciate your hard work
> (because it was easy for me to stand up (first products up within 1 hour of
> GeoServer install). I however have 0% knowledge on how to set up the JNDI
> at all.
> If someone can direct me to how to do it in Windows, I'd really
> appreciate it. I can live with WorldImage, but I'd love to provide my
> users with more than just the most recent image (for looping , etc).
> Earl
> ---- Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
> > Ciao Earl,
> > please, find my answer inline below...
> > Regards,
> > Simone Giannecchini
> > Our support, Your Success! Visit http://opensdi.geo-solutions.it for
> > more information.
> > Ing. Simone Giannecchini
> > @simogeo
> > Founder/Director
> > GeoSolutions S.A.S.
> > Via Poggio alle Viti 1187
> > 55054 Massarosa (LU)
> > Italy
> > phone: +39 0584 962313
> > fax: +39 0584 1660272
> > mob: +39 333 8128928
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > On Sat, Mar 1, 2014 at 8:17 PM, <ebarker111@anonymised.com> wrote:
> > > Trying to create the Image Mosaic store from scratch. Getting this
> error trying to connect to the
> > > Caused by: java.lang.IllegalArgumentException: java.io.IOException:
> Cannot find JNDI data source: java:comp/env/jdbc/postgres
> > > at
> org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.<init>(GTDataStoreGranuleCatalog.java:194)
> > > at
> org.geotools.gce.imagemosaic.catalog.GranuleCatalogFactory.createGranuleCatalog(GranuleCatalogFactory.java:68)
> > > at
> org.geotools.gce.imagemosaic.CatalogManager.createGranuleCatalogFromDatastore(CatalogManager.java:163)
> > It looks like you are trying to access a JNDI connection pool which is
> > not available. Try to create a datastore directly in the UI for
> > GeoServer for that JNDI name to make sure is correct
> > and double check the config in Tomcat (or whateevr the application
> > server you are using is).
> > That said, I would not explicitly force preparedStatements to true.
> > Let us know how it goes.
> > > Three files in additional to the png and pgw files:
> > > datastore.properties :
> > > SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
> > > jndiReferenceName=java:comp/env/jdbc/postgres
> > > host=localhost
> > > port 5432
> > > database=WxCasterData
> > > schema=public
> > > Loose\ bbox=true
> > > Estimated\ extends=false
> > > validate\ connections=true
> > > Connection\ timeout=10
> > > preparedStatements=true
> > > indexer.properties:
> > > TimeAttribute=time
> > > Schema=*geom:Polygon,location:String,time:java.util.Date,
> > > PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](ingestion)
> > > timeregex.properties:
> > > regex=[0-9]{8}T[0-9]{9}Z(\?!.\*[0-9]{8}T[0-9]{9}Z.\*)
> > > ---- ebarker111@anonymised.com wrote:
> > >> Yes, pretty simple image, here is the content:
> > >> 0.01
> > >> 0.0
> > >> 0.0
> > >> -0.01
> > >> -125.0
> > >> 50.0
> > >> ---- Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
> > >> > Hi,
> > >> > Do you also have world files for those images?
> > >> > Daniele
> > >> > Our support, Your Success! Visit http://opensdi.geo-solutions.itfor more
> > >> > information.
> > >> > Ing. Daniele Romagnoli
> > >> > Senior Software Engineer
> > >> > GeoSolutions S.A.S.
> > >> > Italy
> > >> > On Mon, Feb 24, 2014 at 4:00 PM, <ebarker111@anonymised.com> wrote:
> > >> > > Sorry about that.
> > >> > > There are X number of files (I haven't worked out the purging
> of the db,
> > >> > > etc yet). The files are named with the date time. etc
> > >> > > I'll try the mosaic configuration using the mosaicking
> machinery.
> > >> > > thanks.
> wrote:
> > >> > > > Hi,
> > >> > > > keeping the mailing list in the loop for future reference
> regarding
> > >> > > similar
> > >> > > > issues.
> > >> > > > That property file will be automatically created by the
> mosaicking
> > >> > > > machinery.
> > >> > > > Could you retry the mosaic configuration without that file in
> the folder?
> > >> > > > Not sure to fully understand: do you have a single PNG file?
> > >> > > > Cheers,
> > >> > > > Daniele
> > >> > > more
> > >> > > > information.
> > >> > > > GeoSolutions S.A.S.
> > >> > > > Italy
> > >> > > > On Mon, Feb 24, 2014 at 3:26 PM, <ebarker111@anonymised.com> wrote:
> > >> > > > > Daniele,
> > >> > > > > Thanks.. the image is a png, here is the
> > >> > > > > RADAR_NATIONAL_BREF.properties file content: I created the
> file
> > >> > > manually.
> > >> > > > > Levels=0.01,0.01
> > >> > > > > Heterogeneous=false
> > >> > > > > TimeAttribute=time
> > >> > > > > AbsolutePath=false
> > >> > > > > Name=RADAR_NATIONAL_BREF
> > >> > > > > TypeName=RADAR_NATIONAL_BREF
> > >> > > > > Caching=false
> > >> > > > > ExpandToRGB=false
> > >> > > > > LocationAttribute=location
> SuggestedSPI=com.sun.media.imageioimpl.plugins.png.CLibPNGImageReaderSpi
> > >> > > > > LevelsNum=1
> wrote:
> > >> > > > > > Hi,
> > >> > > > > > A couple of questions to gather some more info:
> > >> > > > > > Which format of data are you mosaicking?
> > >> > > > > > Could you please report the content of
> > >> > > RADAR_NATIONAL_BREF.properties?
> > >> > > > > > Does that file it have been automatically created on
> configuration
> > >> > > or did
> > >> > > > > > you set it by yourself?
> > >> > > > > > Please, let us know.
> > >> > > > > > Best Regards,
> > >> > > > > > Daniele
> > >> > > > > more
> > >> > > > > > information.
> > >> > > > > > GeoSolutions S.A.S.
> > >> > > > > > Italy
> > >> > > > > > On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com>
> wrote:
> > >> > > > > > > I'm trying to create a imagemosaic store of radar mosaics
> using
> > >> > > > > postgres
> > >> > > > > > > for feature info. I'm getting the below error when
> trying to save
> > >> > > the
> > >> > > > > > > store. I have a datastore.properties,
> > >> > > > > files
> > >> > > > > > > in the data directory. I created a layer from the failed
> store
> > >> > > > > (allowed me
> > >> > > > > > > to save but still had the error), the feature info
> (validtime,
> > >> > > location
> > >> > > > > > > (filename), region, type are all fine. Just no image. I
> saw a
> > >> > > post in
> > >> > > > > > > Sept 25 2013 similar but no resolution other than update
> for Linux
> > >> > > > > (I'm on
> > >> > > > > > > windows). I am running GeoServer 2.4.4. any help would
> be greatly
> > >> > > > > > > appreciated. thanks. Below is the error message.
> > >> > > > > > > Failed to create reader from
> > >> > > > > > > file://e:\earl-web\radar\geoserver\RADAR_NATIONAL_BREF
> and hints
> > >> > > Hints:
> > >> > > > > > > FILTER_FACTORY = FilterFactoryImpl STYLE_FACTORY =
> StyleFactoryImpl
> > >> > > > > > > FEATURE_FACTORY =
> org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
> > >> > > http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
> > >> > > > > > > EXECUTOR_SERVICE =
> java.util.concurrent.ThreadPoolExecutor@anonymised.com
> > >> > > > > [Running,
> > >> > > > > > > pool size = 0, active threads = 0, queued tasks = 0,
> completed
> > >> > > tasks =
> > >> > > > > 0]
> > >> > > > > > > LENIENT_DATUM_SHIFT = true COMPARISON_TOLERANCE = 1.0E-9
> > >> > > > > > > Managing the Performance of Cloud-Based Applications
> > >> > > > > > > Take advantage of what the Cloud has to offer - Avoid
> Common
> > >> > > Pitfalls.
> > >> > > > > > > Read the Whitepaper.
> http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
> > >> > > > > > > _______________________________________________
> > >> > > > > > > Geoserver-users mailing list
> > >> > > > > > > Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
> > >> Flow-based real-time traffic analytics software. Cisco certified tool.
> > >> Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
> > >> Customize your own dashboards, set traffic alerts and generate
> reports.
> > >> Network behavioral analysis & security monitoring. All-in-one tool.
> http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
> > > Customize your own dashboards, set traffic alerts and generate reports.
> Learn Graph Databases - Download FREE O'Reilly Book
> "Graph Databases" is the definitive new guide to graph databases and their
> applications. Written by three acclaimed leaders in the field,
> this first edition is now available. Download your free book today!
> http://p.sf.net/sfu/13534_NeoTech
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for
more information.
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Earl,
Tomcat is a java based application so it is usable under jvm.
Take a look here:
http://tomcat.apache.org/tomcat-7.0-doc/windows-service-howto.html
Carlo
Il 13/mar/2014 20:04 <ebarker111@anonymised.com> ha scritto:
Cario
thanks. But the only OS that I’ve seen TomCat on are Linux and SUN. I’m on a Windows box, so any instructions on setting up the connection pool from a Windows machine would be awesome.
Earl
Earl,
Carlo
at all.
If someone can direct me to how to do it in Windows, I’d really
appreciate it. I can live with WorldImage, but I’d love to provide my
Earl
Ciao Earl,
please, find my answer inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
at
org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.(GTDataStoreGranuleCatalog.java:194)
at
at
host=localhost
port 5432
schema=public
Loose\ bbox=true
indexer.properties:
TimeAttribute=time
PropertyCollectors=TimestampFileNameExtractorSPItimeregex
regex=[0-9]{8}T[0-9]{9}Z(?!.*[0-9]{8}T[0-9]{9}Z.*)
0.01
0.0
0.0
-0.01
-125.0
50.0
Daniele
information.
Sorry about that.
There are X number of files (I haven’t worked out the purging
of the db,
I’ll try the mosaic configuration using the mosaicking
machinery.
thanks.
wrote:
regarding
similar
issues.
mosaicking
machinery.
the folder?
Daniele
more
information.
Daniele,
Thanks… the image is a png, here is the
file
manually.
Levels=0.01,0.01
Heterogeneous=false
TimeAttribute=time
AbsolutePath=false
Caching=false
ExpandToRGB=false
LevelsNum=1
wrote:
configuration
or did
Best Regards,
Daniele
more
information.
wrote:
I’m trying to create a imagemosaic store of radar mosaics
using
postgres
for feature info. I’m getting the below error when
trying to save
the
files
store
(allowed me
(validtime,
location
saw a
post in
for Linux
(I’m on
be greatly
and hints
Hints:
StyleFactoryImpl
FEATURE_FACTORY =
EXECUTOR_SERVICE =
[Running,
completed
tasks =
0]
Common
Pitfalls.
reports.
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
more information.
@cancellieric
Software Engineer
