[Geoserver-users] Getting an error when trying to save imagemosaic store
Cario,
   Thanks, no luck yet, but at least I have Tomcat installed and running.
    I'm running postgresql for my db. So I downloaded postgresql-9.3-1101.jdbc41.jar and copied it to the C:\Program Files\Apache Software Foundation\Tomcat 7.0\lib
    I added to content.xml in C:\Program Files\Apache Software Foundation\Tomcat 7.0\conf
      Context allowLinking="true">
   <Resource name="jdbc/postgres" auth="Container" type="javax.sql.DataSource"
             url="jdbc:postgresql://127.0.0.1:5432/WxCasterData"
             driverClassName="org.postgresql.driver"
             maxActive="20" maxIdle="3" maxWait="10000"
             poolPreparedStatements="true"
             maxOpenPreparedStatements="100" />
</Context>
   (I removed username and password of course).
    In C:\Program Files (x86)\GeoServer 2.4.4\webapps\geoserver\WEB-INF
    I added to the end of web.xml:
    <welcome-file-list>
        <welcome-file>index.html</welcome-file>
    </welcome-file-list>
    <web-app><resource-ref> <description>Postgres GeoServer Datasource</description> <res-ref-name>jdbc/postgres</res-ref-name> <res-type>javax.sql.DataSource</res-type> <res-auth>Container</res-auth> </resource-ref> </web-app>
   Both services restarted.
   In GeoServer 2.4.4 Admin gui, I selected in Data->Store, the Add New Store widget...
    I then selected PostGIS (JNDI).
    Here is where I may be having problems with...
   I added for Data source name I typed WxCasterDataRaster (I already have a GeoServer Postgres store for WxCasterData (for my vector products)..
   In the jndiRefeerenceName I had : java:comp/env/jdbc/postgres
   schema: public
   nothing for anything else.. I could be wrong on the entire GeoServer for this store.
thanks,
Earl
---- carlo cancellieri <carlo.cancellieri@anonymised.com> wrote:
Earl,
Tomcat is a java based application so it is usable under jvm.
Take a look here:
http://tomcat.apache.org/tomcat-7.0-doc/windows-service-howto.html
Carlo
Il 13/mar/2014 20:04 <ebarker111@anonymised.com> ha scritto:
> Cario
> thanks. But the only OS that I've seen TomCat on are Linux and SUN.
> I'm on a Windows box, so any instructions on setting up the connection
> pool from a Windows machine would be awesome.
> Earl
> > Earl,
> > Error creating data store, check the parameters. Error message: Cannot
> find
> > > JNDI data source: java:comp/env/jdbc/WxCasterData
> > This is probably why you still have to configure the connection pool as
> > resource into your application server.
> > Here is a quick howto to get this working in tomcat:
> http://docs.geoserver.org/stable/en/user/tutorials/tomcat-jndi/tomcat-jndi.html
> > Let we know if this is the case.
> > Cheers,
> > Carlo
> > > Note: I am a Meteorologist who writes applications to process and
> display
> > > various weather products (radar and satellite imagery, model graphics,
> > > forecaster created graphics, etc). I know enough about web hosting on
> my
> > > Windows PC to get IIS installed and running, installing php, etc., I
> know
> > > enough to get GeoServer running (I love viewing my vector graphics
> products
> > > in GeoServer that were stored in Postgres (watches, warnings, mesoscale
> > > discussions, convective outlooks, etc), which I appreciate your hard
> work
> > > (because it was easy for me to stand up (first products up within 1
> hour of
> > > GeoServer install). I however have 0% knowledge on how to set up the
> JNDI
> > > at all.
> > > If someone can direct me to how to do it in Windows, I'd really
> > > appreciate it. I can live with WorldImage, but I'd love to provide my
> > > users with more than just the most recent image (for looping , etc).
> > > Earl
> > > ---- Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
> > > > Ciao Earl,
> > > > please, find my answer inline below...
> > > > Regards,
> > > > Simone Giannecchini
> > > > Our support, Your Success! Visit http://opensdi.geo-solutions.it for
> > > > more information.
> > > > Ing. Simone Giannecchini
> > > > @simogeo
> > > > Founder/Director
> > > > GeoSolutions S.A.S.
> > > > Via Poggio alle Viti 1187
> > > > 55054 Massarosa (LU)
> > > > Italy
> > > > phone: +39 0584 962313
> > > > fax: +39 0584 1660272
> > > > mob: +39 333 8128928
> > > > http://www.geo-solutions.it
> > > > http://twitter.com/geosolutions_it
> > > > On Sat, Mar 1, 2014 at 8:17 PM, <ebarker111@anonymised.com> wrote:
> > > > > Trying to create the Image Mosaic store from scratch. Getting this
> > > error trying to connect to the
> > > > > Caused by: java.lang.IllegalArgumentException: java.io.IOException:
> > > Cannot find JNDI data source: java:comp/env/jdbc/postgres
> > > > > at
> org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.<init>(GTDataStoreGranuleCatalog.java:194)
> > > > > at
> org.geotools.gce.imagemosaic.catalog.GranuleCatalogFactory.createGranuleCatalog(GranuleCatalogFactory.java:68)
> > > > > at
> org.geotools.gce.imagemosaic.CatalogManager.createGranuleCatalogFromDatastore(CatalogManager.java:163)
> > > > It looks like you are trying to access a JNDI connection pool which
> is
> > > > not available. Try to create a datastore directly in the UI for
> > > > GeoServer for that JNDI name to make sure is correct
> > > > and double check the config in Tomcat (or whateevr the application
> > > > server you are using is).
> > > > That said, I would not explicitly force preparedStatements to true.
> > > > Let us know how it goes.
> > > > > Three files in additional to the png and pgw files:
> > > > > datastore.properties :
> > > > > SPI=org.geotools.data.postgis.PostgisNGJNDIDataStoreFactory
> > > > > jndiReferenceName=java:comp/env/jdbc/postgres
> > > > > host=localhost
> > > > > port 5432
> > > > > database=WxCasterData
> > > > > schema=public
> > > > > Loose\ bbox=true
> > > > > Estimated\ extends=false
> > > > > validate\ connections=true
> > > > > Connection\ timeout=10
> > > > > preparedStatements=true
> > > > > indexer.properties:
> > > > > TimeAttribute=time
> > > > > Schema=*geom:Polygon,location:String,time:java.util.Date,
> PropertyCollectors=TimestampFileNameExtractorSPI[timeregex](ingestion)
> > > > > timeregex.properties:
> > > > > regex=[0-9]{8}T[0-9]{9}Z(\?!.\*[0-9]{8}T[0-9]{9}Z.\*)
> > > > > ---- ebarker111@anonymised.com wrote:
> > > > >> Yes, pretty simple image, here is the content:
> > > > >> 0.01
> > > > >> 0.0
> > > > >> 0.0
> > > > >> -0.01
> > > > >> -125.0
> > > > >> 50.0
> > > > >> ---- Daniele Romagnoli <daniele.romagnoli@anonymised.com>
> wrote:
> > > > >> > Hi,
> > > > >> > Do you also have world files for those images?
> > > > >> > Daniele
> http://opensdi.geo-solutions.itfor more
> > > > >> > information.
> > > > >> > Ing. Daniele Romagnoli
> > > > >> > Senior Software Engineer
> > > > >> > GeoSolutions S.A.S.
> > > > >> > Italy
> > > > >> > On Mon, Feb 24, 2014 at 4:00 PM, <ebarker111@anonymised.com> wrote:
> > > > >> > > Sorry about that.
> > > > >> > > There are X number of files (I haven't worked out the
> purging
> > > of the db,
> > > > >> > > etc yet). The files are named with the date time. etc
> > > > >> > > I'll try the mosaic configuration using the mosaicking
> > > machinery.
> > > > >> > > thanks.
> > > wrote:
> > > > >> > > > Hi,
> > > > >> > > > keeping the mailing list in the loop for future reference
> > > regarding
> > > > >> > > similar
> > > > >> > > > issues.
> > > > >> > > > That property file will be automatically created by the
> > > mosaicking
> > > > >> > > > machinery.
> > > > >> > > > Could you retry the mosaic configuration without that file
> in
> > > the folder?
> > > > >> > > > Not sure to fully understand: do you have a single PNG file?
> > > > >> > > > Cheers,
> > > > >> > > > Daniele
> > > > >> > > more
> > > > >> > > > information.
> > > > >> > > > GeoSolutions S.A.S.
> > > > >> > > > Italy
> > > > >> > > > On Mon, Feb 24, 2014 at 3:26 PM, <ebarker111@anonymised.com>
> wrote:
> > > > >> > > > > Daniele,
> > > > >> > > > > Thanks.. the image is a png, here is the
> > > > >> > > > > RADAR_NATIONAL_BREF.properties file content: I created
> the
> > > file
> > > > >> > > manually.
> > > > >> > > > > Levels=0.01,0.01
> > > > >> > > > > Heterogeneous=false
> > > > >> > > > > TimeAttribute=time
> > > > >> > > > > AbsolutePath=false
> > > > >> > > > > Name=RADAR_NATIONAL_BREF
> > > > >> > > > > TypeName=RADAR_NATIONAL_BREF
> > > > >> > > > > Caching=false
> > > > >> > > > > ExpandToRGB=false
> > > > >> > > > > LocationAttribute=location
> SuggestedSPI=com.sun.media.imageioimpl.plugins.png.CLibPNGImageReaderSpi
> > > > >> > > > > LevelsNum=1
> > > wrote:
> > > > >> > > > > > Hi,
> > > > >> > > > > > A couple of questions to gather some more info:
> > > > >> > > > > > Which format of data are you mosaicking?
> > > > >> > > > > > Could you please report the content of
> > > > >> > > RADAR_NATIONAL_BREF.properties?
> > > > >> > > > > > Does that file it have been automatically created on
> > > configuration
> > > > >> > > or did
> > > > >> > > > > > you set it by yourself?
> > > > >> > > > > > Please, let us know.
> > > > >> > > > > > Best Regards,
> > > > >> > > > > > Daniele
> > > > >> > > > > more
> > > > >> > > > > > information.
> > > > >> > > > > > GeoSolutions S.A.S.
> > > > >> > > > > > Italy
> > > > >> > > > > > On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com>
> > > wrote:
> > > > >> > > > > > > I'm trying to create a imagemosaic store of radar
> mosaics
> > > using
> > > > >> > > > > postgres
> > > > >> > > > > > > for feature info. I'm getting the below error when
> > > trying to save
> > > > >> > > the
> > > > >> > > > > > > store. I have a datastore.properties,
> > > > >> > > > > files
> > > > >> > > > > > > in the data directory. I created a layer from the
> failed
> > > store
> > > > >> > > > > (allowed me
> > > > >> > > > > > > to save but still had the error), the feature info
> > > (validtime,
> > > > >> > > location
> > > > >> > > > > > > (filename), region, type are all fine. Just no
> image. I
> > > saw a
> > > > >> > > post in
> > > > >> > > > > > > Sept 25 2013 similar but no resolution other than
> update
> > > for Linux
> > > > >> > > > > (I'm on
> > > > >> > > > > > > windows). I am running GeoServer 2.4.4. any help
> would
> > > be greatly
> > > > >> > > > > > > appreciated. thanks. Below is the error message.
> > > > >> > > > > > > Failed to create reader from
> > > > >> > > > > > > file://e:\earl-web\radar\geoserver\RADAR_NATIONAL_BREF
> > > and hints
> > > > >> > > Hints:
> > > > >> > > > > > > FILTER_FACTORY = FilterFactoryImpl STYLE_FACTORY =
> > > StyleFactoryImpl
> > > > >> > > > > > > FEATURE_FACTORY =
> org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
> > > > >> > > http FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
> > > > >> > > > > > > EXECUTOR_SERVICE =
> > > java.util.concurrent.ThreadPoolExecutor@anonymised.com
> > > > >> > > > > [Running,
> > > > >> > > > > > > pool size = 0, active threads = 0, queued tasks = 0,
> > > completed
> > > > >> > > tasks =
> > > > >> > > > > 0]
> > > > >> > > > > > > LENIENT_DATUM_SHIFT = true COMPARISON_TOLERANCE =
> 1.0E-9
> > > > >> > > > > > > Managing the Performance of Cloud-Based Applications
> > > > >> > > > > > > Take advantage of what the Cloud has to offer - Avoid
> > > Common
> > > > >> > > Pitfalls.
> > > > >> > > > > > > Read the Whitepaper.
> http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
> > > > >> > > > > > > _______________________________________________
> > > > >> > > > > > > Geoserver-users mailing list
> > > > >> > > > > > > Geoserver-users@lists.sourceforge.net
> > > https://lists.sourceforge.net/lists/listinfo/geoserver-users
> > > > >> Flow-based real-time traffic analytics software. Cisco certified
> tool.
> > > > >> Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow
> Analyzer
> > > > >> Customize your own dashboards, set traffic alerts and generate
> > > reports.
> > > > >> Network behavioral analysis & security monitoring. All-in-one
> tool.
> http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
> tool.
> Analyzer
> reports.
> > > > > Network behavioral analysis & security monitoring. All-in-one tool.
> > > Learn Graph Databases - Download FREE O'Reilly Book
> > > "Graph Databases" is the definitive new guide to graph databases and
> their
> > > applications. Written by three acclaimed leaders in the field,
> > > this first edition is now available. Download your free book today!
> > > http://p.sf.net/sfu/13534_NeoTech
> > Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK for
> > more information.
> > Dott. Carlo Cancellieri
> > @cancellieric
> > Software Engineer
> > GeoSolutions S.A.S.
> > Italy
Ciao,
you also need to remove the driver from the geoserver WEB-INF/lib
directory for this to work.
Check this post:
http://bit.ly/1hgM5wn
Simone Giannecchini
for more information.
@simogeo
Founder/Director
On Thu, Mar 13, 2014 at 11:20 PM, <ebarker111@anonymised.com> wrote:
Cario,
</Context>
    <welcome-file-list>
   schema: public
thanks,
Earl
Earl,
Take a look here:
Carlo
> Cario
> Earl
> > Earl,
> find
> > Cheers,
> > Carlo
> display
> my
> know
> products
> work
> hour of
> JNDI
> > > at all.
> > > Earl
> > > > Ciao Earl,
> > > > Regards,
> > > > Simone Giannecchini
> > > > more information.
> > > > @simogeo
> > > > Founder/Director
> > > > GeoSolutions S.A.S.
> > > > Italy
> > > > > at
> > > > > at
> > > > > at
> is
> > > > > host=localhost
> > > > > port 5432
> > > > > schema=public
> > > > > Loose\ bbox=true
> > > > > indexer.properties:
> > > > > TimeAttribute=time
> > > > >> 0.01
> > > > >> 0.0
> > > > >> 0.0
> > > > >> -0.01
> > > > >> -125.0
> > > > >> 50.0
> wrote:
> > > > >> > Hi,
> > > > >> > Daniele
> > > > >> > information.
> > > > >> > GeoSolutions S.A.S.
> > > > >> > Italy
> > > > >> > > Sorry about that.
> purging
> > > of the db,
> > > machinery.
> > > > >> > > thanks.
> > > wrote:
> > > > >> > > > Hi,
> > > regarding
> > > > >> > > similar
> > > > >> > > > issues.
> > > mosaicking
> > > > >> > > > machinery.
> in
> > > the folder?
> > > > >> > > > Cheers,
> > > > >> > > > Daniele
> > > > >> > > more
> > > > >> > > > information.
> > > > >> > > > GeoSolutions S.A.S.
> > > > >> > > > Italy
> wrote:
> > > > >> > > > > Daniele,
> the
> > > file
> > > > >> > > manually.
> > > > >> > > > > Levels=0.01,0.01
> > > > >> > > > > Heterogeneous=false
> > > > >> > > > > TimeAttribute=time
> > > > >> > > > > AbsolutePath=false
> > > > >> > > > > Caching=false
> > > > >> > > > > ExpandToRGB=false
> > > > >> > > > > LevelsNum=1
> > > wrote:
> > > > >> > > > > > Hi,
> > > configuration
> > > > >> > > or did
> > > > >> > > > > > Best Regards,
> > > > >> > > > > > Daniele
> > > > >> > > > > more
> > > > >> > > > > > information.
> > > > >> > > > > > GeoSolutions S.A.S.
> > > > >> > > > > > Italy
> mosaics
> > > using
> > > > >> > > > > postgres
> > > trying to save
> > > > >> > > the
> > > > >> > > > > files
> failed
> > > store
> > > > >> > > > > (allowed me
> > > (validtime,
> > > > >> > > location
> image. I
> > > saw a
> > > > >> > > post in
> update
> > > for Linux
> > > > >> > > > > (I'm on
> would
> > > be greatly
> > > and hints
> > > > >> > > Hints:
> > > StyleFactoryImpl
> > > > >> > > > > > > FEATURE_FACTORY =
> > > > >> > > > > > > EXECUTOR_SERVICE =
> > > > >> > > > > [Running,
> > > completed
> > > > >> > > tasks =
> > > > >> > > > > 0]
> 1.0E-9
> > > Common
> > > > >> > > Pitfalls.
> tool.
> Analyzer
> > > reports.
> tool.
> tool.
> Analyzer
> reports.
> their
> > more information.
> > @cancellieric
> > Software Engineer
> > GeoSolutions S.A.S.
> > Italy
Earl,
I’m with my tablet so I can’t verify your jndi configuration anyhow consider that my suggestions are just in addiction to the Simone’s ones.
If you need an image mosaic with jndi support you still have to use the image mosaic coverage store pointing to the target folder containing the images and datastore.properties as previously suggested.
Ciao,
Carlo
Il 13/mar/2014 23:21 <ebarker111@anonymised.com> ha scritto:
Cario,
I’m running postgresql for my db. So I downloaded postgresql-9.3-1101.jdbc41.jar and copied it to the C:\Program Files\Apache Software Foundation\Tomcat 7.0\lib
Context allowLinking=“true”>
index.html Postgres GeoServer Datasource jdbc/postgres javax.sql.DataSource Container
In GeoServer 2.4.4 Admin gui, I selected in Data->Store, the Add New Store widget…
Here is where I may be having problems with…
I added for Data source name I typed WxCasterDataRaster (I already have a GeoServer Postgres store for WxCasterData (for my vector products)…
schema: public
nothing for anything else… I could be wrong on the entire GeoServer for this store.
thanks,
Earl
Earl,
Take a look here:
Carlo
Cario
thanks. But the only OS that I’ve seen TomCat on are Linux and SUN.
I’m on a Windows box, so any instructions on setting up the connection
Earl
Earl,
find
Carlo
display
my
know
products
work
hour of
JNDI
at all.
If someone can direct me to how to do it in Windows, I’d really
appreciate it. I can live with WorldImage, but I’d love to provide my
Earl
Ciao Earl,
please, find my answer inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
at
org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.(GTDataStoreGranuleCatalog.java:194)
at
at
is
host=localhost
port 5432
schema=public
Loose\ bbox=true
indexer.properties:
TimeAttribute=time
PropertyCollectors=TimestampFileNameExtractorSPItimeregex
regex=[0-9]{8}T[0-9]{9}Z(?!.*[0-9]{8}T[0-9]{9}Z.*)
0.01
0.0
0.0
-0.01
-125.0
50.0
wrote:
Daniele
information.
Sorry about that.
There are X number of files (I haven’t worked out the
purging
of the db,
I’ll try the mosaic configuration using the mosaicking
machinery.
thanks.
wrote:
regarding
similar
issues.
mosaicking
machinery.
in
the folder?
Daniele
more
information.
wrote:
Daniele,
Thanks… the image is a png, here is the
the
file
manually.
Levels=0.01,0.01
Heterogeneous=false
TimeAttribute=time
AbsolutePath=false
Caching=false
ExpandToRGB=false
LevelsNum=1
wrote:
configuration
or did
Best Regards,
Daniele
more
information.
On Sun, Feb 23, 2014 at 1:45 AM, <ebarker111@anonymised.com.6375…>
wrote:
I’m trying to create a imagemosaic store of radar
mosaics
using
postgres
for feature info. I’m getting the below error when
trying to save
the
files
failed
store
(allowed me
(validtime,
location
image. I
saw a
post in
update
for Linux
(I’m on
would
be greatly
and hints
Hints:
StyleFactoryImpl
FEATURE_FACTORY =
EXECUTOR_SERVICE =
[Running,
completed
tasks =
0]
1.0E-9
Common
Pitfalls.
Geoserver-users@anonymised.comorge.net
tool.
Analyzer
reports.
tool.
tool.
Analyzer
reports.
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and
their
more information.
@cancellieric
Software Engineer
