Thanx, This is with out the doupt the kick I needed to get started..
regards
Einar
----- Upprunalegt skeyti -----
Frá: "Simone Giannecchini" <simone.giannecchini@anonymised.com>
Til: "Einar Guðsteinsson" <einsigu@anonymised.com>
Cc: "geoserver-users users" <geoserver-users@lists.sourceforge.net>
Sent: Fimmtudagur, 12. febrúar, 2009 01:33:30 GMT +00:00 Casablanca / Monrovia
Efni: Re: [Geoserver-users] Getting started with geoserver
Ciao Einar,
a few quick suggestions:
Jpeg is not the best format for GIS + Java, I would suggest you to:
1> convert your tiff files to tiled geotiff
2> add overviews to your tiff files
3> create a mosaic
4> serve the mosaic with geoserver
Here you have some sample documentation that describe how to this preprocessing with open source tools:
- http://geoserver.org/display/GEOSDOC/High+performance+coverage+serving
- http://geoserver.org/display/GEOSDOC/Creating+a+coverage+from+a+TIFF+with+world+file+(tfw)
- http://geoserver.org/display/GEOSDOC/MrSID+mosaic,+GeoWebCache+and+Super+Overlays
make sure to give the tutorials a look in that order, however, feel free to come back with questions.
Ciao,
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Wed, Feb 11, 2009 at 11:07 PM, Einar Guðsteinsson < einsigu@anonymised.com... > wrote:
I managed to work this out with one jpg raster file (I had tryed this
tutorial before but always choosed wrong type
). There are two slight
proplems tough. When I goto the demo and zoom in the map will go all white.
Is there any config or something I can try? Secondly, I have 66 of those
jpg files that make one area. Is there quick way to put the all in there?
best regards
Einar
----- Original Message -----
To: "geoserver-users users" < geoserver-users@lists.sourceforge.net >
Sent: Tuesday, February 10, 2009 11:45 AM
Subject: Re: [Geoserver-users] Getting started with geoserver
http://geoserver.org/display/GEOSDOC/User+Tutorial+Coverage
Just choose a different format as appropriate to your need.
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Feb 10, 2009, at 5:54 AM, einsigu@anonymised.com wrote:
Hi all.
I am trying to get started using geoserver but having some
difficulties. What I firstly and mostly need todo is to add few jpg
rasterfiles to the server but I can't find good example or tutorial
todo that. Can anyone point me the right direction.
best regards
Einar
Create and Deploy Rich Internet Apps outside the browser with
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills
and code to
build responsive, highly engaging applications that combine the
power of local
resources and data with the reach of the web. Download the Adobe AIR
SDK and
Ajax docs to start building applications
today- http://p.sf.net/sfu/adobe-com
Geoserver-users mailing list
Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code
to
build responsive, highly engaging applications that combine the power of
local
resources and data with the reach of the web. Download the Adobe AIR SDK
and
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today- http://p.sf.net/sfu/adobe-com
