[Geoserver-users] Getting started with Oracle
I’ve set up the Oracle Connector plugin and correctly configured it.
I have published two tables that have spatial fields in them.
When previewing the first layer, I just get a blank map
When previewing the second layer, I get a blank map with an error: “code=”internalError” Rendering process failed / by zero
Any ideas what’s going on?
Details of first layer:
Coordinate Reference Systems
Native SRS
UNKNOWN Longitude / Latitude (WGS 84)…
Declared SRS
EPSG:900913 EPSG:WGS84 / Google Mercator…
SRS handling
Force Declared
Bounding Boxes
Native Bounding Box
Min X -11.112
Min Y 48.744
Max X 2.513
Max Y 61.581
Lat/Lon Bounding Box
Min X -12.15
Min Y 47.85
Max X 3.15
Max Y 63.15
Feature Type Details
Property Type Nillable Min/Max Occurences
GRIDREF String false 1/1
SYSTEM String false 1/1
PARENT String true 0/1
TYPE BigDecimal false 1/1
BOUNDARY Geometry true 0/1
Details of second layer:
Native SRS
Declared SRS
SRS handling
Force Declared
Bounding Boxes
Native Bounding Box
Min X -33.407
Min Y 25.682
Max X 45.343
Max Y 71.032
Min X -33
Min Y 25
Max X 46
Max Y 72
REGION_CODE String false 1/1
REGION_NAME String false 1/1
ADDED_DATE Date false 1/1
LAST_EDITED Date false 1/1
LAST_EDIT_BY String true 0/1
EDITABLE String false 1/1
Error from error log:
2011-11-25 09:54:24,678 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Rendering process failed
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:491)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:228)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:122)
at org.geoserver.wms.GetMap.run(GetMap.java:377)
at org.geoserver.wms.GetMap.run(GetMap.java:107)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:352)
at sun.reflect.GeneratedMethodAccessor1340.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:60)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:56)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:38)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy363.getMap(Unknown Source)
at sun.reflect.GeneratedMethodAccessor1339.invoke(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:630)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:234)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:735)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.apache.catalina.core.StandardWrapper.service(StandardWrapper.java:1534)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:343)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:215)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:256)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:74)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:45)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:49)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:46)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:279)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at org.apache.catalina.core.StandardPipeline.doInvoke(StandardPipeline.java:655)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:595)
at com.sun.enterprise.web.WebPipeline.invoke(WebPipeline.java:98)
at com.sun.enterprise.web.PESessionLockingStandardPipeline.invoke(PESessionLockingStandardPipeline.java:91)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:162)
at org.apache.catalina.connector.CoyoteAdapter.doService(CoyoteAdapter.java:326)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:227)
at com.sun.enterprise.v3.services.impl.ContainerMapper.service(ContainerMapper.java:170)
at com.sun.grizzly.http.ProcessorTask.invokeAdapter(ProcessorTask.java:822)
at com.sun.grizzly.http.ProcessorTask.doProcess(ProcessorTask.java:719)
at com.sun.grizzly.http.ProcessorTask.process(ProcessorTask.java:1013)
at com.sun.grizzly.http.DefaultProtocolFilter.execute(DefaultProtocolFilter.java:225)
at com.sun.grizzly.DefaultProtocolChain.executeProtocolFilter(DefaultProtocolChain.java:137)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:104)
at com.sun.grizzly.DefaultProtocolChain.execute(DefaultProtocolChain.java:90)
at com.sun.grizzly.http.HttpProtocolChain.execute(HttpProtocolChain.java:79)
at com.sun.grizzly.ProtocolChainContextTask.doCall(ProtocolChainContextTask.java:54)
at com.sun.grizzly.SelectionKeyContextTask.call(SelectionKeyContextTask.java:59)
at com.sun.grizzly.ContextTask.run(ContextTask.java:71)
at com.sun.grizzly.util.AbstractThreadPool$Worker.doWork(AbstractThreadPool.java:532)
at com.sun.grizzly.util.AbstractThreadPool$Worker.run(AbstractThreadPool.java:513)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.ArithmeticException: / by zero
at org.geotools.data.oracle.sdo.SDO.coordinates(SDO.java:2075)
at org.geotools.data.oracle.sdo.SDO.create(SDO.java:2320)
at org.geotools.data.oracle.sdo.GeometryConverter.asGeometry(GeometryConverter.java:124)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:438)
at org.geotools.data.oracle.OracleDialect.readGeometry(OracleDialect.java:424)
at org.geotools.data.oracle.OracleDialect.decodeGeometryValue(OracleDialect.java:387)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:321)
at org.geotools.jdbc.JDBCFeatureReader.next(JDBCFeatureReader.java:85)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:190)
at org.geotools.data.store.ContentFeatureCollection$WrappingFeatureIterator.next(ContentFeatureCollection.java:170)
at org.geotools.data.crs.ForceCoordinateSystemIterator.next(ForceCoordinateSystemIterator.java:125)
at org.geotools.data.crs.ForceCoordinateSystemIterator.next(ForceCoordinateSystemIterator.java:66)
at org.geotools.renderer.lite.StreamingRenderer.drawPlain(StreamingRenderer.java:2019)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1940)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:772)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:465)
… 106 more
2011-11-25 09:54:29,135 ERROR [geotools.rendering] - / by zero
Looks like your data is in 4326 not 909913.
Ian
Thanks for the heads up.
Have republished the tables using 4326, and while it correctly calculated the bounds this time, the results on preview layer were the same - blank map for one table, and the divide by zero error with the other.
Both these tables' spatial fields can be previewed OK using the SQL Developer Map view.
M
-----Original Message-----
Sent: 25 November 2011 10:28
To: Mark Hammond
Subject: Re: [Geoserver-users] Getting started with Oracle
Ian
On Tue, Nov 29, 2011 at 10:35 AM, Mark Hammond <mark.hammond@anonymised.com> wrote:
Both these tables’ spatial fields can be previewed OK using the SQL Developer Map view.
A division by zero is likely to indicate corrupted data on your end. The SQL Developer Map viewer is
probably more tolerant to it.
I believe Oracle has functions that allow to locate and fix corrupt gometries.
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
Wasn’t able to find this tool you mention, so have asked on the Oracle forum about it.
While I was there, I did find an article discussing the differences between SRID 8307 (traditional used by Oracle) and SRID 4326. They are supposed to be equivalent, but could this be a source of the trouble?
https://forums.oracle.com/forums/thread.jspa?threadID=2302685&tstart=0
Mark
From: andrea.aime@anonymised.com… [mailto:andrea.aime@anonymised.com] On Behalf Of Andrea Aime
Sent: 29 November 2011 13:30
To: Mark Hammond
Cc: Ian Turton; geoserver-users@lists.sourceforge.net
Ing. Andrea Aime
Tech lead
On Wed, Nov 30, 2011 at 12:15 PM, Mark Hammond <mark.hammond@anonymised.com> wrote:
about it.
http://docs.oracle.com/cd/B19306_01/appdev.102/b14255/sdo_util.htm#BJEICGGA
http://docs.oracle.com/html/A88805_01/sdo_objg.htm
It should not.
Ing. Andrea Aime
Tech lead
Thanks for your help.
With the clues you offered, I was able to pinpoint the problem down to the
original Oracle tool that created populated the database table from a shape
file. This had created spatial objects of an older version than current and
neither the oracle SDO_UTIL.RECTIFY_GEOMETRY nor GeoServer could do anything
with them.
For anyone else attempting this, run the SDO_MIGRATE.TO_CURRENT function on
your loaded spatial data to bring it up to date, then you can use a
combination of SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT function to check for
problems, and SDO_UTIL.RECTIFY_GEOMETRY to fix them.
Now onto the second part of my original question:
I'd like to be able to pull back features onto my map from GeoServer based
on an SQL (or SQL-like) query. The trouble is there are two or three tables
that I want to include in the query of which only one of them contains the
spatial data. Can such a thing be achieved with GeoServer, or am I going to
need create a list of features direct from Oracle first, and then query
GeoServer with that list (could be quite a long list, so I'd like to avoid
that if possible). Are there any other solutions to this kind of problem?
From: andrea.aime@anonymised.com [mailto:andrea.aime@anonymised.com] On Behalf Of
Andrea Aime
Sent: 30 November 2011 13:19
To: Mark Hammond
forum about it.
It should not.
Ing. Andrea Aime
Tech lead
Perhaps you can handle the situation by creating a view into Oracle and publishing it with Geoserver. It is similar process than publishing tables. Remember to add a line into geometry columns table and often it is also good to make a primary key for the view. That is possible with Oracle. Primary key columns are used for generating fids. With standard settings the PK columns are not included as attributes. If you need them there are a few alternatives. Myself I am doing it by picking those attributes two times with different names into a view. For example if fids in the view must contain IDs from table_1 and table_2 to be unique you can do something like
create or replase view geoserver_view as
(select first.ID PK_1, first.ID ID_1, second.ID PK_2, second.ID ID_2
from first_table first, second_table second);
Then create primary key for geoserver_view as PK_1 and PK_2. Fids will contain both PK_1 and PK_2 and in addition the original table IDs are published in WFS as ID_1 and ID_2 attributes.
-Jukka Rahkonen-
problem down to the
table from a shape
than current and
could do anything
with them.
GeoServer based
or three tables
contains the
am I going to
then query
like to avoid
of problem?
Behalf Of
Andrea Aime
To: Mark Hammond
> Wasn't able to find this tool you mention, so have asked on
the Oracle
> forum about it.
.htm#BJEICGGA
4326. They are
the trouble?
It should not.
Ing. Andrea Aime
Tech lead
All the data continuously generated in your IT infrastructure
contains a definitive record of customers, application performance,
security threats, fraudulent activity, and more. Splunk takes this
data and makes sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-novd2d
Geoserver-users mailing list
Rahkonen,
This is the approach I thought may be necessary. Apparently a carefully
managed materialised view can minimise the amount of work Oracle has to do
to maintain a view, since the spatial data itself won't be changing.
The only trouble at the moment is when creating the view: The query involves
a spatial join which just locks up the server and never completes (I left it
8 hours just to make sure it wasn't just a slow query)
I've posted some details on that problem to the Oracle forum in the hope of
some sensible advice.
From: Rahkonen Jukka [mailto:Jukka.Rahkonen@anonymised.com]
Sent: 01 December 2011 09:48
To: 'Mark Hammond'; 'geoserver-users@lists.sourceforge.net'
create or replase view geoserver_view as (select first.ID PK_1, first.ID
ID_1, second.ID PK_2, second.ID ID_2 ...
-Jukka Rahkonen-
the original Oracle tool that created populated the database table
from a shape file. This had created spatial objects of an older
version than current and neither the oracle SDO_UTIL.RECTIFY_GEOMETRY
nor GeoServer could do anything with them.
function on your loaded spatial data to bring it up to date, then you
can use a combination of SDO_GEOM.VALIDATE_GEOMETRY_WITH_CONTEXT
based on an SQL (or SQL-like) query. The trouble is there are two or
three tables that I want to include in the query of which only one of
them contains the spatial data. Can such a thing be achieved with
GeoServer, or am I going to need create a list of features direct from
Oracle first, and then query GeoServer with that list (could be quite
a long list, so I'd like to avoid that if possible). Are there any
Of Andrea Aime
To: Mark Hammond
the Oracle
> forum about it.
.htm#BJEICGGA
4326. They are
the trouble?
It should not.
Ing. Andrea Aime
Tech lead
All the data continuously generated in your IT infrastructure contains
a definitive record of customers, application performance, security
threats, fraudulent activity, and more. Splunk takes this data and
