Hi folks,
I’ve been looking at how to best prepare historical aerial photos for Geoserver. I had issues with exporting from ArcMap the individual aerial frames into Geotiffs – losing quality along the way. I’ve since worked that out.
I tried to apply Paul Ramsey’s GDAL steps to the exported files but didn’t get very far as these errors occurred:
C:\Program Files (x86)\GDAL>gdal_translate.exe -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co TILED=YES Aerial_1930.tif Aerial_1930-new.tif
Input file size is 3541, 3438
ERROR 1: MissingRequired:TIFF directory is missing required “StripOffsets” field
0ERROR 6: PHOTOMETRIC=YCBCR requires a source raster with only 3 bands (RGB)
The 1930 aerial frame is black and white (as you would expect for the era). So I think the 2nd error is related to that. I tried removing the PHOTOMETRIC option from the command but…
C:\Program Files (x86)\GDAL>gdal_translate.exe -co COMPRESS=JPEG -co TILED=YES Aerial_1930.tif Aerial_1930-new.tif
0…10…20…30…40…50…60…70…80ERROR 1: JPEGSetupEncode:BitsPerSample 16 not allowed for JPEG
…ERROR 1: An error occured while writing a dirty block
I decided to turn to a more recent image:
C:\Program Files (x86)\GDAL>gdal_translate.exe -co COMPRESS=JPEG -co PHOTOMETRIC=YCBCR -co TILED=YES Aerial_1994.tif Aerial_1994-new.tif
Input file size is 5521, 5361
0…ERROR 1: JPEGSetupEncode:BitsPerSample 16 not allowed for JPEG
ERROR 1: WriteEncodedTile/Strip() failed.
This is the first workflow I’ve tried and I’m open to any that others on the list might use when preparing Geotiff for Geoserver.
Many thanks and happy Friday (in Australia),
Neil
Sent: Wednesday, 21 July 2021 4:09 PM
To: Neil Saunders <neil.saunders@…9733…>
Subject: Re: [Geoserver-users] Getting the best results with Raster
Neil:
Can you describe more in what way the quality is lacking? Is it distorted, or pixelated, or what? Did you do any data prep to your geotiff, say introduce an overview? If so what sampling technique did you use?
What does “gdalinfo” return for your image?
Some general guidance from Paul Ramsey is here https://blog.cleverelephant.ca/2015/02/geotiff-compression-for-dummies.html
Jody Garnett
On Tue, 20 Jul 2021 at 19:00, Neil Saunders <neil.saunders@…9733…> wrote:
Hi folks,
Apologies if this is a basic question – I’m fairly new to GIS data.
I’m using Geoserver 2.18.2 to host historical aerial clips and exporting the rasters with Arc Map 10.6 to Geotiff with a 500m buffer of a property. However I’m finding the quality of the image in Geoserver does not match the quality in Arc Map when zoomed in.
I’ve tried exporting at different DPI but find 300 or above has no discernible improvement. I’m not using any compression when creating the TIFF and using GeoTIFF Tags. I’ve read about resampling and how it can alter the image quality but not sure if that’s it.
Assuming this is not a new challenge, I’m curious what steps others have taken to get raster clips into Geoserver in a way that doesn’t compromise the image quality? I’m using the most detailed historical aerial photography as the use case requires inspection of features at the street level. Any help gratefully received!
Kind Regards,
Neil Saunders
Business Consultant
CONFIDENTIAL INFORMATION This transmission may be privileged and may contain confidential information intended only for the recipient(s) named above. Any other distribution, re-transmission, copying or disclosure of this message is strictly prohibited. If you have received this transmission in error, please notify me immediately by telephone or return email, and delete this message from your system. Thank you.
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
