[Geoserver-users] Getting the Legend as JSON
Form ArcMap service - we get JSON for Legend similar to this
https://pxxxx.com/arcgis/rest/services/aaa/aaa/MapServer/Legend?f=pjson&token=ddddd.&callback=angular.callbacks._0
angular.callbacks._0({ "layers": [ { "layerId": 1, "layerName": "abc", "layerType": "Feature Layer", "minScale": 0, "maxScale": 0, "legend": [ { "label": "", "url": "76d5be60e5691543860aa46358f5dcf8", "imageData": "iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAYAAACNiR0NAAAAAXNSR0IB2cksfwAAAAlwSFlzAAAOxAAADsQBlSsOGwAAAF9JREFUOI1jYaAyYIExzFcw/EeXPBnBwEisPIaBlACYZScjGBjhBmKzjZBrsAGquBDDQGQnU8VAagKqGIjss8HpQgwDKY0MrOmQWmA0HZIH6J8OKSkbqZIOCbqQkrIRAPKcIWF3tuu1AAAAAElFTkSuQmCC "contentType": "image/png", "height": 20, "width": 20 } ] },
Geoserver has the option getlegendgraphics for WMS- which is returning image. I will need something similar as above. I noticed this proposed change: https://github.com/geoserver/geoserver/wiki/GSIP-81—GetLegendGraphic-as-text-(JSON)
Is it part of any release? I am beginner in geoserver and have installed 2.8.2 (stable release) recently. Please advise.
Thanks
there is no json support for GetLegendGraphics, the proposal you’re linking to
never got approved and implemented… sorry! :slight_smile:
Also see in the master proposal list, it’s listed below the “deferred and rejected” proposals:
https://github.com/geoserver/geoserver/wiki/Proposals#deferred-and-rejected-proposals
That does not mean it cannot be implemented, one has to check why it got there, fix
the problem (could have been never voted, or had some negative feedback that was
not addressed) and make sure there are enough developer time to actually have it implemented.
See also this page:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
On Thu, Mar 17, 2016 at 3:45 PM, Deepti Puri <deepti202jais@anonymised.com> wrote:
Thanks
Transform Data into Opportunity.
Accelerate data analysis in your applications with
Intel Data Analytics Acceleration Library.
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Note that there is the “GetStyles” request (it’s part of the SLD spec) - this returns the Style used for the layer as XML.
There are various convertors out there to convert XML to JSON - if you plugged one of them in as a piece of middleware between the client which needs JSON and GeoServer which is returning XML, you can probably get the desired outcome.
You can then parse the JSON to determine what the legend should be; easy for simple things (i.e. a polygon with a fill), but probably not desirable for more complex styles.
Jonathan
---- On Thu, 17 Mar 2016 14:45:43 +0000 Deepti Purideepti202jais@anonymised.com wrote ----
Thanks
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140_______________________________________________
