[Geoserver-users] Getting Unable to transform referenced envelope, crs has not yet been provided ERROR on GetCapabilities
I have a problem when requesting WMS GetCapabilities from geoserver 2.12 and can not figure out what happens.
We are using an Oracle 12c database to store our features. Most of our features are in EPSG:4326 but also have some in our local Hungarian coordinate system EPSG:23700.
The application using the geoserver always need the features in EPSG:4326, so we try to use geoserver to reproject between the coordinate systems.
This is the way we define these layers:
Native CRS: EPSG:23700
Declared CRS: EPSG:4326
SRS handling: Reproject native to declared
In the Bounding Boxes section on the web UI for the Native Bounding Box I click Compute from data, I get EPSG:4236 numbers, definitely not EPSG:23700 numbers, I do not understand why since this should be the Native bounding box. When I set Compute from SRS bounds -180,-90,180,90 is set. If at Lat/Lon Bounding box I click Compute from native bounds I get the same values.
When I save this layer, after running a GetCapabilities WMS request I get the following error at the end of the produced XML:
<<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE ServiceExceptionReport SYSTEM "http://192.168.96.33:8080/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd&quot;&gt; <ServiceExceptionReport version="1.1.1" > <ServiceException>
      javax.xml.transform.TransformerException: org.geoserver.platform.ServiceException: Error occurred trying to write out metadata for layer: PLAN_INPUT_IGENYHELY
Unexpected error obtaining bounding box for layer PLAN_INPUT_IGENYHELY
Unable to transform referenced envelope, crs has not yet been provided.
</ServiceException></ServiceExceptionReport>
Thank you,
Laszlo
I experience the same when going to Layer preview and try to download the layer as GML:
java.lang.RuntimeException: java.lang.NullPointerException: Unable to transform referenced envelope, crs has not yet been provided. java.lang.NullPointerException: Unable to transform referenced envelope, crs has not yet been provided. Unable to transform referenced envelope, crs has not yet been provided.
The wierd thing is that some of my layers with the same settings work, some gives the above error.
I have already restarted Tomcat to force reload configuration but no change.
Laszlo
On 2018. Apr 18., at 19:35, László Németh <nlaszlo1976@anonymised.com> wrote:
Thank you,
Laszlo
When you first configured them, did GeoServer recognize a native SRS?
If not, that might be the cause, it might not have a CRS in the native bounding box config,
which is required in order to use “reproject to declared”.
Try forcing a “compute from data” or manually updating the bbox, or even re-create the layer,
to see if that works.
Alternatively, check if the tables in question really declare the SRS you’re think they are using,
at the database level.
On Wed, Apr 18, 2018 at 7:44 PM, László Németh <nlaszlo1976@anonymised.com> wrote:
Laszlo
Thank you,
Laszlo
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Geoserver-users@anonymised.com.382…sourceforge.net
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Hi Andrea,
Thank you for your answer. I did some tests.
  1. Deleted all workspaces in the workspaces configuration except the tested one.
  2. Tried downloading Layer preview in KML for the problematic layer → I get the error.
  3. Deleted the layer and recreated as new. Geoserver did figure our the Native SRS based on DB info. If I use “compute from data” I get 0,0,-1-1, since the table is empty, so I used “compute from SRS” and I get -180,-90,180,90.
  4. Tried downloading Layer preview in KML for the problematic layer → SUCCESS
  5. Diffed the two featuretype XML files and the only difference I see that the one with the error has a line: EPSG:23700 in the nativeboundingbox XML section.
I attached the two XMLs. Removing the line and inserting EPSG:4326 instead solved the problem on other problematic layers as well. Could you please clarify why?
Thank you,
Laszlo
Laszlo
Thank you,
Laszlo
Geoserver-users@anonymised.comsourceforge.net
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
On Thu, Apr 19, 2018 at 6:45 AM, László Németh <nlaszlo1976@...84...>
wrote:
Hi Andrea,
tested one.
2. Tried downloading Layer preview in KML for the problematic layer -> I
get the error.
-180,-90,180,90.
This seems wrong, the native bbox should be native. If your data is in
EPSG:23700 the bound coordinates should be too. I guess the UI is confused
by the "reproject native to declared" setting, but I'm not sure,
I did not work on adding the "compute from SRS" functionality.
4. Tried downloading Layer preview in KML for the problematic layer ->
SUCCESS
the one with the error has a line: <crs class="projected">EPSG:23700</crs>
inserting <crs>EPSG:4326</crs> instead solved the problem on other
I don't know, my guess is that it's working by accident.
Here is a sample from a working layer that I have locally, in a projected
crs (but mind the projected coordinates here):
  <nativeBoundingBox>
    <minx>-840901.150827375</minx>
    <maxx>872858.801962177</maxx>
    <miny>2966776.48464754</miny>
    <maxy>5029485.2911404</maxy>
    <crs class="projected">EPSG:32654</crs>
  </nativeBoundingBox>
GeoServer Professional Services from the experts! Visit GeoSolutions Enterprise Support Services
Ing. Andrea Aime
@geowolf
Technical Lead
Thanks again. Could you please help what to look for in the code of the UI?
Is SRS bounds stored in the SRS definition? Could it be that EPSG:23700 SRS definition is not correct?
Laszlo
On Thu, Apr 19, 2018 at 6:45 AM, László Németh <nlaszlo1976@anonymised.com> wrote:
Hi Andrea,
This seems wrong, the native bbox should be native. If your data is in EPSG:23700 the bound coordinates should be too. I guess the UI is confused by the “reproject native to declared” setting, but I’m not sure,
I did not work on adding the “compute from SRS” functionality.
  1. Tried downloading Layer preview in KML for the problematic layer → SUCCESS
  2. Diffed the two featuretype XML files and the only difference I see that the one with the error has a line: EPSG:23700 in the nativeboundingbox XML section.
I don’t know, my guess is that it’s working by accident.
Here is a sample from a working layer that I have locally, in a projected crs (but mind the projected coordinates here):
-840901.150827375 872858.801962177 2966776.48464754 5029485.2911404 EPSG:32654
Ing. Andrea Aime
@geowolf
Technical Lead
the code area should be this one:
https://github.com/geoserver/geoserver/blob/4d043080a8f80c76c325810d021632fdd3e9636f/src/web/core/src/main/java/org/geoserver/web/data/resource/BasicResourceConfig.java#L152
In case you want to contribute fixes here are directions and requests:
https://github.com/geoserver/geoserver/blob/master/CONTRIBUTING.md
On Thu, Apr 19, 2018 at 9:45 AM, László Németh <nlaszlo1976@anonymised.com> wrote:
Laszlo
Hi Andrea,
Ing. Andrea Aime
@geowolf
Technical Lead
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
