Hi All,
Not sure if this is documented somewhere - which GML-3 geometries are supported in GeoServer?
Alex
Hi All,
Alex
Hi Alex,
All the "simple" geometries:
Point
LineString
Polygon
And each of there "Multi" Counterparts.
Now when we come to curves and surfaces, here is where things get interesting. We do support the encoding and parsing of curves and surfaces, but only those that can be represented by line strings and polygons. Ie, we have no internal representation of a true curve or surface.
Does that make sense?
Alex Milanovic wrote:
Hi All,
Alex------------------------------------------------------------------------
Create and Deploy Rich Internet Apps outside the browser with Adobe(R)AIR(TM)
software. With Adobe AIR, Ajax developers can use existing skills and code to
build responsive, highly engaging applications that combine the power of local
resources and data with the reach of the web. Download the Adobe AIR SDK and
Ajax docs to start building applications today-http://p.sf.net/sfu/adobe-com------------------------------------------------------------------------
Geoserver-users mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
