2015-10-17 10:52 GMT+02:00 Andrea Aime <andrea.aime@anonymised.com>:
Hi Georges,
not sure if you noticed already, but the message was sent to the wrong mailing list
(This one is for GeoServer, not GeoNetwork)
On Wed, Oct 14, 2015 at 5:35 PM, Georges H <georges.hinot@anonymised.com> wrote:
Hi
I use GN 3.0.0.0
But with Mozilla, I have a problem with the map. Indeed, the map is cut from the left…
Thanks to fgravin, which has done a commit to fix that, here:
https://github.com/geonetwork/core-geonetwork/commit/e2debf0338491c681f14c2a9792e9b431d70919d
But I can not apply it. I have done the change, but without improvment on my GN.
What about the .less ? Is there a manipulation to force the changes ?
Thank you !
Georges Hinot
CNRS - DRIIHM - UMS BBEES (3468)
Musée d’Histoire Naturelle de Paris, Maison Buffon
Géomaticien - Administrateur BDD - Intégrateur
Tél : 01 40 79 80 44
Tél : 06 47 61 84 92
Le site du LabEx DRIIHM
Le métacalogue du LabEx DRIIHM
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Georges Hinot
georges.hinot@anonymised.com…
