[Geoserver-users] google earth network link to geoserver workspace
Greetings – I’ve read the GeoServer manual basics for accessing a layer via a Google Earth network link, but am curious if there is a syntax to access a GeoServer workspace via network link? What I’d like is the ability for my users to selectively display one or more layers in Google Earth from the workspace via a common network link, rather than require that they enter a unique network link for each and every layer.
Many thanks,
Jim P.
Hi Jim,
A few months ago I created and released a script which would parse a WMS GetCapabilities file and convert it into a KML file.
See here:
http://osgeo-org.1560.x6.nabble.com/rel-Script-to-convert-WMS-GetCapabilities-to-a-KML-file-td5088032.html
If you point it at a GetCapabilities which is using a workspace namespace then it should only list the layers in that workspace. (not tested that; but think it should)
Hopefully that helps (and works!)
Jonathan
This transmission is intended for the named addressee(s) only and may contain confidential, sensitive or personal information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Many thanks,
Jim P.
“Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free.”
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
