On Wed, Mar 16, 2016 at 1:48 PM, Volkan Gümüs <hallo@anonymised.com> wrote:
I'm trying to rotate an external graphic resource using <Rotation> in SLD:
http://pastebin.com/GkmgyYW1
The documentation lists the Rotation-Tag as a valid element of <Graphic>
Unfortunately it is not working. Do you see an error in my sld?
Looks legit. Glancing at the code that paints graphics strokes, it seems to
me the graphic
rotation is taken into account for marks only:
https://github.com/geotools/geotools/blob/master/modules/library/render/src/main/java/org/geotools/renderer/lite/StyledShapePainter.java#L629
Feel free to open a bug report at
https://osgeo-org.atlassian.net/projects/GEOT (a pull request with a patch
to fix it would
be very much appreciated too! :-p )
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
