[Geoserver-users] Graphics not showing?
I am trying to show highway shield graphics, but the shields are not showing.
Here is basically what I am doing:
        <Rule>
          <ogc:Filter>
          </ogc:Filter>
          <MinScaleDenominator>3e6</MinScaleDenominator>
          <PointSymbolizer>
            <Graphic>
              <ExternalGraphic>
                <OnlineResource
xlink:href="http://localhost:8080/geoserver/openlayers/img/shieldIThin.gif&quot;/&gt;
                <Format>image/gif</Format>
              </ExternalGraphic>
            </Graphic>
          </PointSymbolizer>
          <TextSymbolizer>
            <Label>
              <ogc:PropertyName>routenum</ogc:PropertyName>
            </Label>
            <Fill>
              <CssParameter name="fill">#333333</CssParameter>
            </Fill>
            <VendorOption name="group">yes</VendorOption>
            <VendorOption name="spaceAround">10</VendorOption>
          </TextSymbolizer>
        </Rule>
The label does show up, but the image does not. I verified that the image is
available at this url, and the log shows that the image is successfully
fetched.
I also tried using:
<Graphic>
  <Mark>
    <WellKnownName>square</WellKnownName>
    <Fill>
      <CssParameter name="fill">#ff0000</CssParameter>
      <CssParameter name="fill-opacity">1.0</CssParameter>
    </Fill>
  </Mark>
  <Size>8.0</Size>
</Graphic>
Instead of the Graphic tag above; that did not show, either.
By the way, I also tried the image in my styles directory, which is
something I've seen people recommend in this forum. As expected, that didn't
help.
Can anyone tell me what I'm doing wrong?
View this message in context: http://www.nabble.com/Graphics-not-showing--tp16015064p16015064.html
Hi geoman. I've done a little bit of SLD troubleshooting. It is odd that the label is showing up but not the graphic. Some things that come to mind to test (please note that I am no expert):
1. Change the format of the graphic to something else (PNG?)
2. Take out all of the rules ogc:filters, or as much as possible
3. Make sure that this particular rule is at the very bottom of the SLD (to make sure that nothing is overprinting the shields)
This may not be the solution, but it may give you some more insight into the problem. Hope this helps.
Mike Pumphrey
Outreach Engineer
The Open Planning Project
        <Rule>
          <ogc:Filter>
          </ogc:Filter>
          <PointSymbolizer>
            <Graphic>
              <ExternalGraphic>
                <OnlineResource
              </ExternalGraphic>
            </Graphic>
          </PointSymbolizer>
          <TextSymbolizer>
            <Label>
            </Label>
                        <Fill>
            </Fill>
          </TextSymbolizer>
        </Rule>
fetched.
I also tried using:
<Graphic>
  <Mark>
    <Fill>
    </Fill>
  </Mark>
  <Size>8.0</Size>
</Graphic>
help.
It looks like when I have a Rule with both a LineSymbolizer and a
PointSymbolizer for my roads, then the PointSymbolizer is ignored.
However, when I take out the LineSymbolizer, the PointSymbolizer repeats its
Graphic all along the road. I tried the VendorOption of group, which seems
to work for Labels with the TextSymbolizer, but that didn't improve the
display of the PointSymbolizer.
I have seen a few places (such as
http://lyceum.massgis.state.ma.us/wiki/doku.php?id=wms:sld:graphics_with_labels_inside)
where the Graphic element is added to a TextSymbolizer. However, when I
tried this my styles would not validate under GeoServer. I saw a javadoc for
a TextSymbolizer2 which makes this work, but that had a comment calling it a
hack. I would like to do this in a way that won't break in a future release.
Is there an accepted way to get a road sign symbol under a route number in
GeoServer?
View this message in context: http://www.nabble.com/Graphics-not-showing--tp16015064p16037040.html
Hi, lucky for you "hacks" have a way of staying around for a while longer than you might think :). Saul can comment further but I believe this was the only way he could get this type of graphic labeling to work. So if it works for you, I think its probably safe to do. GeoServer will still render styles which are not "xml valid".
-Justin
GeoServer?
Justin Deoliveira
jdeolive@anonymised.com
Yep, this "graphics in a textsymbolizer" method was approved as a
geotools SLD extension back when I committed it, so it should stick
around for a while.
Plus my employer (who maintains that wiki where you found the sld
graphics with the label inside page) has a vested interest in keeping it
around, so they'll provide the coding power to keep it working if it
gets broken later.
--saul
-Justin
> GeoServer?
