Hello,
I create a vector map in the "feature editor". after "submit" ,"apply" and
"save" it appears, in the console, the following message:
GRAVE: Attempting to create file:c\geoserver\...\featureType\..\info.xml.
I can load the map, but the diagram isn't correct.
Maybe someone knows where the problem could be?
Regards
Gabriel
View this message in context: http://www.nabble.com/grave%3A-Attempting-to-create-file%3Ac%3A\geoserver\...\featureType\..\info.xml-tp15087469p15087469.html
gabriel dmon ha scritto:
Hello,
Hard to tell, this is not enough information. Can you look into
the GeoServer logs and see if you can fine a stack trace (it's a fuller
error information with java files and line numbers of how the problem
was generated).
See also this faq item:
http://docs.codehaus.org/pages/viewpage.action?pageId=57507870
Hello,
I used the 1.5.4 version.
But with the 1.6.0 RC3 Version it works fine!
Cheers!
was generated).
View this message in context: http://www.nabble.com/grave%3A-Attempting-to-create-file%3Ac%3A\geoserver\...\featureType\..\info.xml-tp15087469p15330890.html
