Hello everybody
I'm a Spanish Java Web GIS Analyst who is working now with
geoserver (great software indeed!). We are now evaluating WCS server
with Geoserver 1.4 RC2. Everything works fine with examples, but we
cannot add our own geotiff files in our own spatial reference system
(UTM 30N WGS 84 SRID=32630). We found a built-in example very similar,
WGS84 33N (in Germany).
We have changed prj file, with our parameters (30 N) but we
do not know if it is right or not. How can we get a correct prj file? We
have used ArcGIS prj files, but it does not seem to work.
PS.: I have attached a txt file with all the information
about the error.
Thank you in advance!!!
WCS_Error.txt (9.93 KB)
Is it possible to have a sample file to try here with your prj too?
On 11/8/06, Aitor Calero Garcia <aitor.calero@anonymised.com > wrote:
Hello everybody
I’m a Spanish Java Web GIS Analyst who is working now with geoserver (great software indeed!). We are now evaluating WCS server with Geoserver 1.4 RC2. Everything works fine with examples, but we cannot add our own geotiff files in our own spatial reference system (UTM 30N WGS 84 SRID=32630). We found a built-in example very similar, WGS84 33N (in Germany).
We have changed prj file, with our parameters (30 N) but we do not know if it is right or not. How can we get a correct prj file? We have used ArcGIS prj files, but it does not seem to work.
PS.: I have attached a txt file with all the information about the error.
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-users mailing list
Eng. Alessio Fabiani
Vice President/CTO GeoSolutions
I have just tried your prj WKT and it works fine on my side, even if I haven’t a good tiff file example, but at least I have no exceptions.
P.S.> I’m using GeoServer + WCS 1.5.x
On 11/8/06, Aitor Calero Garcia < aitor.calero@anonymised.com > wrote:
Hello everybody
