[Geoserver-users] Greetings
I’m a Slovak student,
and I’ve been using Geoserver for a while and the newest stable version of it doesn’t run on firefox allegedly due to recursive redirections or so it said. Geoserver 2.24.0 is the last version that worked on Firefox.
Firefox is stricter about security than other browsers and I think it’s a matter of time before other browsers up their security measures as well. So could you consider testing your webapp on Firefox, too? Thanks. I searched the usage of Firefox and due to the low percentage of usage I understand why you wouldn’t really mind to test on Firefox.
Is the Photo Mosaic JDBC plugin still up to date? Or is it canceled? Your documentation isn’t very exhaustive and it contains plenty of outdated links that don’t work anymore.
I appreciate the time you spent reading this. I hope I helped. I’m going to downgrade back to the last version that worked for me.
Have a nice day
  • Šimon Janovič
Good morning Simon
Thank you for your input. We rely on community participation to pick up any regressions.
Can I please trouble you for more information on how to reproduce the problem that you are experiencing? I think a number of us also use Firefox, without any problems.
Here I am logged into GeoServer main branch (2.25-SNAPSHOT), using the latest Firefox browser on Windows (v122.0.1), without “recursive redirections”.
What am I doing differently to you?
Peter
GeoServer PSC
AWS Solutions Architect
https://github.com/petersmythe
I use Firefox for testing GeoServer, I have not run into the problem you describe.
Can you be more specific about what the trouble is?
Jody Garnett
Hi Simon,
the Mosaic JDBC plugin was dropped years ago because we lacked a maintainer for it.
The documentation is versioned, the current one should not contain information about that plugin anymore:
https://docs.geoserver.org/latest/en/user/
If you find any outdated link, please use the “edit” button available in the right side of the page:
It will open and editor, you can correct the link, saving will create documentation Pull Request with the update
Best regards
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
