I'm trying to export to KML format from "Demos" window with Geoserver 2.5
and got an error.
I also tested in Geoserver 2.4.4 and got the same error.
With Geoserver 2.1.4 the export to KML has been successful.
*The Test:*
-> Installed Geoserver 2.5 Stable;
-> Go to "Demos" window; --> Request: WMS_getMap.xml
-> Change the <Output><Format> to:
--> kml
--> application/vnd.google-earth.kmz+xml
--> application/vnd.google-earth.kml+xml
*Example:*
/<?xml version="1.0" encoding="UTF-8"?>
<ogc:GetMap xmlns:ogc="http://www.opengis.net/ows"
xmlns:gml="http://www.opengis.net/gml"
version="1.1.1" service="WMS">
<StyledLayerDescriptor version="1.0.0">
<NamedLayer>
<Name>topp:states</Name>
<NamedStyle><Name>population</Name></NamedStyle>
</NamedLayer>
</StyledLayerDescriptor>
<BoundingBox srsName="http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:coord><gml:X>-130</gml:X><gml:Y>24</gml:Y></gml:coord>
<gml:coord><gml:X>-55</gml:X><gml:Y>50</gml:Y></gml:coord>
</BoundingBox>
<Output>
<Format>image/png</Format>
<Size><Width>550</Width><Height>250</Height></Size>
</Output>
</ogc:GetMap>
With all the three format options i get this error:
<?xml version="1.0" encoding="UTF-8" standalone="no"?><!DOCTYPE
ServiceExceptionReport SYSTEM
"http://localhost:8081/geoserver/schemas/wms/1.1.1/WMS_exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1" > <ServiceException>
java.lang.NullPointerException
null
</ServiceException></ServiceExceptionReport>
Can anyone help?
Thanks
Tiago Vieira
View this message in context: http://osgeo-org.1560.x6.nabble.com/GS-2-5-Error-Exporting-to-KML-format-within-XML-Body-tp5132293.html
I get the same errors with POST requests and GS 2.5.
GET returns data
http://localhost:8080/geoserver/wms?bbox=-130,24,-66,50&styles=population&Format=application/vnd.google-earth.kml+xml&request=GetMap&layers=topp:states&width=550&height=250&srs=EPSG:4326
-Jukka Rahkonen-
T. Vieira wrote:
and got an error.
*The Test:*
-> Go to "Demos" window; --> Request: WMS_getMap.xml Change the
-> <Output><Format> to:
--> kml
*Example:*
<NamedLayer>
</NamedLayer>
</BoundingBox>
<Output>
</Output>
</ogc:GetMap>
_1_1.dtd">
null
Can anyone help?
Thanks
Tiago Vieira
Geoserver-users mailing list
Hi Rahkonen,
Can you open a ticket (defect) on Geoserver JIRA with that information?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/GS-2-5-Error-Exporting-to-KML-format-within-XML-Body-tp5132293p5133543.html
