Thenks a lot! I’ll verify it!
Endre
From: alessio.fabiani@anonymised.com [mailto:alessio.fabiani@anonymised.com.84…] On Behalf Of Alessio Fabiani
Sent: Tuesday, October 08, 2013 4:34 PM
To: Holb Endre
Cc: geoserver-users
Subject: Re: [Geoserver-users] gs:Contour error
As far as I remember there should be an issue in that GeoServer version with the Contour rendering transformation which is fixed on 2.4.x version.
I’m not completely sure, have to verify, but in the meantime you may want to test the latest GeoServer version to see if it’s working fine.
-A.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via Poggio alle Viti 1187
mob: +39 331 6233686
On Tue, Oct 8, 2013 at 4:02 PM, Holb Endre <holb.endre@anonymised.com> wrote:
Hy!
I’m trying to apply gs:Contour WPS process with the WPS request builder. My Geoserver version 2.3.1. I’ve downloaded the approriate WPS extension.
I use the original sf:sfdem raster file. This raster file is ok with the original dem sld style. But when I execute the process the result is an error :
filled input parameters: data, interval
Process failed during execution
java.lang.IllegalArgumentException: The input argument(s) may not be null.
Can you help me?
Thenks
Endre Holb a developer
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60134071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
