[Geoserver-users] gs-gwc-distributed-2.10-SNAPSHOT.jar broken?
I'm trying unsuccessfully to enable Hazelcast in-memory caching using package downloaded from:
http://ares.boundlessgeo.com/geoserver/2.9.x/community-latest/geoserver-2.9-SNAPSHOT-gwc-distributed-plugin.zip
Jul 25, 2016 1:16:48 PM org.geoserver.platform.GeoServerExtensions extensionNames
WARNING: bean lookup error
org.springframework.beans.factory.CannotLoadBeanClassException: Cannot find class [org.geowebcache.storage.blobstore.memory.distributed.HazelcastCacheProvider] for bean with name 'HazelCastCacheProvider' defined in URL [jar:file:
/opt/apache-tomcat-7.0.69/webapps/geoserver/WEB-INF/lib/gs-gwc-distributed-2.9-SNAPSHOT.jar!/applicationContext.xml]; nested exception is java.lang.ClassNotFoundException: org.geowebcache.storage.blobstore.memory.distributed.Haze
lcastCacheProvider
I'm afraid that gs-gwc-distributed-2.9-SNAPSHOT.jar is somehow broken.
Maciej
See:
https://osgeo-org.atlassian.net/browse/GEOS-7657
Maciej
Thanks for investigating and the bug report.
I've proposed a PR against master, which local testing shows adds the
missing jar.
Hopefully that can get merged and you can test a new nightly build.
Brad
This should now be available for testing in a nightly build.
If you can verify that the module is OK in 2.10-SNAPSHOT, I'll propose the
backport for 2.9.
Brad
-----Original Message-----
Sent: Wednesday, 27 July 2016 20:23
To: 'Maciej Filocha' <m.filocha@anonymised.com>; 'GeoServer Mailing List List'
<geoserver-users@lists.sourceforge.net>
Subject: Re: [Geoserver-users] gs-gwc-distributed-2.10-SNAPSHOT.jar
broken?
missing jar.
Brad
What NetFlow Analyzer can do for you? Monitors network bandwidth and
traffic
patterns at an interface-level. Reveals which users, apps, and protocols
are
consuming the most bandwidth. Provides multi-vendor support for NetFlow,
J-Flow, sFlow and other flows. Make informed decisions using capacity
planning
reports.http://sdm.link/zohodev2dev
Geoserver-users mailing list
