[Geoserver-users] gs:Unique performance over HTTP GET
I’m calling the following URL through a javascript application to obtain the unique neighborhood’s names of my neighborhood layer.
http://.../geoserver/wps?service=WPS&version=1.0.0&request=Execute&identifier=gs:Unique&DataInputs=attribute%3dnome;features%3d%40xlink%3ahref%3dhttp://.../geoserver/smurb/ows%3Fservice=WFS%26version=1.0.0%26request=GetFeature%26typeName=smurb:bairros_vigentes_3857%26propertyName%3dnome&RawDataOutput=result%3dformat%40mimetype%3dapplication%2Fjson
The problem is that this call takes like 10 seconds to execute and the layer has like 90 geometries only. If I make the “same” call through GeoServer’s WPS Request Builder, it executes almost instantaneously, but I suspect it doesn’t do HTTP requests.
Anyway, there are any tips to improve it’s performance? Other suggestion to obtain the same results are also accepted :slight_smile:
Additional info:
  • Geoserver 2.7.2
  • Linux machine
  • “…” in the URL means my GeoServer host
  • The response has 1.2 kb
On Tue, Nov 17, 2015 at 4:07 PM, César Augusto Ribeiro <carrbrpoa@anonymised.com4...>
wrote:
I'm calling the following URL through a javascript application to obtain
the unique neighborhood's names of my neighborhood layer.
http://
.../geoserver/wps?service=WPS&version=1.0.0&request=Execute&identifier=gs:Unique&DataInputs=attribute%3dnome;features%3d%40xlink%3ahref%3dhttp://…/geoserver/smurb/ows%3Fservice=WFS%26version=1.0.0%26request=GetFeature%26typeName=smurb:bairros_vigentes_3857%26propertyName%3dnome&RawDataOutput=result%3dformat%40mimetype%3dapplication%2Fjson
layer has like 90 geometries only. If I make the "same" call through
GeoServer's WPS Request Builder, it executes almost instantaneously, but I
suspect it doesn't do HTTP requests.
It indeed does a HTTP request, but it's a local one.
I would suggest against using GET requests though, indeed those requests in
WPS were problematic
enough that OGC dropped support for GET requests in WPS 2.0
The request builder can create the XML for a POST request for you, second
button at the bottom
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
(Why spam?)
Hey Andrea,
I need to do these requests in an javascript application. I suppose I can’t rely on request builder to do it, I’m I wrong?
I understand that OGC dropped support, so the recommended way is to build the “xml” in my application and then POST it somehow?
Do you believe it would have any performance gain?
Thanks
2015-11-17 13:17 GMT-02:00 Andrea Aime <andrea.aime@…1107…>:
On Tue, Nov 17, 2015 at 4:07 PM, César Augusto Ribeiro <carrbrpoa@anonymised.com> wrote:
It indeed does a HTTP request, but it’s a local one.
I would suggest against using GET requests though, indeed those requests in WPS were problematic
The request builder can create the XML for a POST request for you, second button at the bottom
Ing. Andrea Aime
@geowolf
Technical Lead
Atenciosamente,
César Augusto R. Ribeiro
On Tue, Nov 17, 2015 at 4:27 PM, César Augusto Ribeiro <carrbrpoa@anonymised.com4...>
wrote:
(Why spam?)
Don't know, the server of our mail provider adds it automatically...
Hey Andrea,
can't rely on request builder to do it, I'm I wrong?
You're not
the "xml" in my application and then POST it somehow?
Yes
Honestly I don't know, but the request builder actually does a local HTTP
POST request, so, if it's fast,
that might be involved
Ing. Andrea Aime
@geowolf
Technical Lead
On 18/11/15 22:54, Andrea Aime wrote:
On Tue, Nov 17, 2015 at 4:27 PM, César Augusto Ribeiro <carrbrpoa@anonymised.com>
wrote:
(Why spam?)
Looks like SpamAssassin, which adds this string to enable client-side filtering, running on the mail server. In addition to dubious senders and mail servers, SpamAssassin can also detect spam based on content. I suggest that words like "unique", "performance", and "neighborhood" in close proximity might look like spam. I have seen a beef jerky recipe that could not be delivered because it contained the word "meat" many times in close proximity (blocked by IronPort in that case). Our robot overlords never sleep.
Kind regards,
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Thanks for the support, Andrea.
I’ve done my tests:
I’m using AngularJS for the front-end and changed the request to POST. With the help of WPS Request Builder, I grabbed the XML it builds (needed to modify) and made a test request like this:
var xmlString = ‘<?xml version="1.0" encoding="UTF-8"?><wps:Execute version=“1.0.0” service=“WPS” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns=“http://www.opengis.net/wps/1.0.0” xmlns:wfs=“http://www.opengis.net/wfs” xmlns:wps=“http://www.opengis.net/wps/1.0.0” xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:gml=“http://www.opengis.net/gml” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:wcs=“http://www.opengis.net/wcs/1.1.1” xmlns:xlink=“http://www.w3.org/1999/xlink” xsi:schemaLocation=“http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd”>ows:Identifiergs:Unique</ows:Identifier>wps:DataInputswps:Inputows:Identifierfeatures</ows:Identifier><wps:Reference mimeType=“text/xml” xlink:href=“http://…/geoserver/wfs” method=“POST”>wps:Body<![CDATA[]]></wps:Body></wps:Reference></wps:Input>wps:Inputows:Identifierattribute</ows:Identifier>wps:Datawps:LiteralDatanome</wps:LiteralData></wps:Data></wps:Input></wps:DataInputs>wps:ResponseForm<wps:RawDataOutput mimeType=“application/json”>ows:Identifierresult</ows:Identifier></wps:RawDataOutput></wps:ResponseForm></wps:Execute>’;
return $http({
url : rootUrl,
method : ‘POST’,
data : xmlString,
headers : {
‘Content-Type’ : ‘application/xml’
// </Test code>
PS: I’ve suffered to figure out the CDATA stuff and the xmlns:wfs inside wfs:GetFeature... (the modifications I pointed before)
The result is the same response time: like 10 seconds for 1.2kb ~ 1.3kb data.
I don’t know what I could try to monitor/make better, since the latency to the server is fine ( < 1ms).
I’m accepting ideas :wink:
2015-11-18 7:54 GMT-02:00 Andrea Aime <andrea.aime@anonymised.com>:
On Tue, Nov 17, 2015 at 4:27 PM, César Augusto Ribeiro <carrbrpoa@anonymised.com> wrote:
(Why spam?)
Don’t know, the server of our mail provider adds it automatically…
Hey Andrea,
You’re not
Yes
Honestly I don’t know, but the request builder actually does a local HTTP POST request, so, if it’s fast,
Ing. Andrea Aime
@geowolf
Technical Lead
Atenciosamente,
