hi all,
I have deployed the GS1.6 RC2 war under the tomcat 5.5.
When I started tomcat,it reported log as below:
__________________________________________________
25 十二月 09:44:32 ERROR [context.ContextLoader] - Context initialization
failed
org.springframework.beans.factory.BeanCreationException: Error creating bean
with name 'geoServer' defined in URL
[jar:file:/e:/Apache/Tomcat%205.5/webapps/geoserver/WEB-INF/lib/main-1.6.0-RC2.jar!/applicationContext.xml]:
Instantiation of bean failed; nested exception is
org.springframework.beans.FatalBeanException: Could not instantiate class
[org.vfny.geoserver.global.GeoServer]; constructor threw exception; nested
exception is java.lang.NoSuchFieldError: KEY_CACHED_TILE_RECYCLING_ENABLED
at org.vfny.geoserver.global.GeoServer.initJAI(GeoServer.java:719)
at org.vfny.geoserver.global.GeoServer.load(GeoServer.java:494)
at org.vfny.geoserver.global.GeoServer.<init>(GeoServer.java:129)
I have used GS for a long time,but I never see that before.
So anyone can help me?
Thanks in advance of any tips.
regards
minimeteor
View this message in context: http://www.nabble.com/GS1.6-RC2-cannt-work-under-tomcat-tp14492681p14492681.html
This looks like a jai error. Are you sure you have jai and the image io
extensions installed in the jdk that is running tomcat? Just in case you
do not have them installed here is where you can get them:
JAI (1.1.3): https://jai.dev.java.net/binary-builds.html
IMAGEIO (1.1): https://jai-imageio.dev.java.net/binary-builds.html
-Justin
minimeteor wrote:
hi all,
failed
regards
minimeteor
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
minimeteor ha scritto:
hi all,
failed
Hum, this question is becoming common enough that I've added a FAQ for it:
http://docs.codehaus.org/pages/viewpage.action?pageId=41484313
Let me know if this helps
