I have put together a new improvement proposal where I state my
intentions to have some of the GeoServer modules implement a Status
interface, which allows them to report their current status (stopped or
started) and any associated errors. This will allow a remote client to
query the GeoServer to ensure that all required modules are running.
PS. I apologize if it’s not very complete or coherent right now. Quite
exhausted from moving and having trouble concentrating
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
This will be very cool!! I made some comments on the page and provided
some feedback. Will sum up here. This basically looks like something
very simple that provides the same functionality as JMX. So I am weary
about having GeoServer components implement interfaces that we have
rolled on our own. Instead it would be nice to reverse the dependency,
and make Status and Modules wrappers that accept components, the
components being plain old java objects. This makes it trivial to swap
in another technology when someone gets the time to do the JMX research.
-Justin
Richard Gould wrote:
PS. I apologize if it's not very complete or coherent right now. Quite
Geoserver-devel mailing list
Geoserver-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-devel
!DSPAM:1004,44ea3c7457161702038478!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
We had the same suggestion in the Skype meeting yesterday, ... Richard any chance you can set an IRC breakout time on this subject? (Alessio was going to email you the request).
Justin I think we have structured it the way you requested... modules is the api we are going to check, and Status is the "components" it is going to accept.
You are correct that we should treat the lifecycle question as a separate problem ... so how about it Justin how do we ask GeoServer to "reload"?
And we just call make use of those callbacks during a create/load/save/dispose lifecycle?
Justin if you get some time to chat I would like to try and recreate the various stepping stones a module can cross as it grows up for eventual inclusion in GeoServer.
Jody
Hi Richard,
-Justin
My main concern was to not have geoserver start implementing these
interfaces all over the place. It makes all of our code dependent on
these interfaces we have rolled our own. And when it comes time and we
may want to do things with JMX,
My other concern is the inventing of our own plugin framework when there
are alternatives available.
I included some comments on the GSIP as to how I thought you could leave
the core of geoserver alone and still pull this off. Its very similar to
how spring publishes beans with JMX.
-Justin
going to accept.
"reload"?
Jody
Hi Richard,
-Justin
I invite you to make comments on it here: http://docs.codehaus.org/display/GEOS/GSIP+4+-+Status+Interface
Richard
