[Geoserver-users] GTDataStoreGranuleCatalog class error
Hi
I’m using the image mosaic plugin and I get the following error from the GTDataStoreGranuleCatalog class intermittently.
BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
If I try to recreate the image mosaic overlay it’ll work fine. Do you have any idea why this would be happening?
My indexer.properties file contains the following
TimeAttribute = validtime
ElevationAttribute = elevation
Envelope2D = 119.00390624999999,0.3515625,129.00390625,10.3515625
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date,elevation:Double
PropertyCollectors = TimestampFileNameExtractorSPItimeregex,DoubleFileNameExtractorSPIelevationregex
Thanks
Dominique
On Sat, Nov 14, 2015 at 1:20 AM, Bessette-Halsema, Dominique E <
Dominique.Bessette@anonymised.com> wrote:
Hi
the featureSource
Do you have the full stack trace?
What version of GeoServer is giving you these errors?
Schema =
TimestampFileNameExtractorSPI[timeregex](validtime),DoubleFileNameExtractorSPI[elevationregex](elevation)
Where are you storing the collected granules? If it's a database, can you
share your datastore.properties?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
