Ive gotten a little farther with my debugging.
In the GTDataStoreGranuleCatalog class line 226 the extractBasicProperties method, it tries to pass in a typename = “schemaversion”. schemaversion is a table and stores schema creation information. Why is the code reading in a table that not part of the imagemosaic? This happens intermittently.
More debugging:
GTDataStoreGranuleCatalog line 176, scanForTypeNames is true
GTDataStoreGranuleCatalog line 182, String typeNames = [missionid1_coaid1_aoiid0_ruleid2_thresholdid2, schemaversion] where missionid1_coaid1_aoiid0_ruleid2_thresholdid2 is correct
GTDataStoreGranuleCatalog line 192, typeNames.iterator().next = schemaversion
GTDataStoreGranuleCatalog breaks because schema.getGeometryDescriptor()==null and throws error described below. This is fact correct, the schemaversion table does not contain a geometry bbox, but imagemosaic should not be scanning it in.
20:31:06,133 DEBUG [class org.geotools.gce.imagemosaic.ImageMosaicFormat] (http-/0.0.0.0:8080-2) java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource: org.geotools.data.DataSourceException: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:470) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:483) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:103) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1436) [gs-main-2.7.2-nn-1.jar:2.7.2-nn-1]
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1337) [gs-main-2.7.2-nn-1.jar:2.7.2-nn-1]
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1332) [gs-main-2.7.2-nn-1.jar:2.7.2-nn-1]
at org.geoserver.catalog.CatalogBuilder.initCoverage(CatalogBuilder.java:776) [gs-main-2.7.2-nn-1.jar:2.7.2-nn-1]
at org.geoserver.catalog.rest.CoverageResource.handleObjectPost(CoverageResource.java:87) [gs-restconfig-2.7.2.jar:2.7.2]
at org.geoserver.rest.ReflectiveResource.handlePost(ReflectiveResource.java:121) [gs-rest-2.7.2.jar:2.7.2]
at org.restlet.Finder.handle(Finder.java:296) [org.restlet-1.0.8.jar:]
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38) [gs-rest-2.7.2.jar:2.7.2]
at org.restlet.Filter.doHandle(Filter.java:105) [org.restlet-1.0.8.jar:]
at org.restlet.Filter.handle(Filter.java:134) [org.restlet-1.0.8.jar:]
at org.restlet.Router.handle(Router.java:444) [org.restlet-1.0.8.jar:]
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:205) [gs-rest-2.7.2.jar:2.7.2]
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129) [com.noelios.restlet.ext.servlet-1.0.8.jar:]
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:87) [gs-rest-2.7.2.jar:2.7.2]
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789) [spring-webmvc-3.1.4.RELEASE.jar:3.1.4.RELEASE]
at java.lang.Thread.run(Thread.java:745) [rt.jar:1.7.0_72]
Caused by: org.geotools.data.DataSourceException: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:643) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.(ImageMosaicReader.java:468) [gt-imagemosaic-13.2-nn-1.jar:]
… 100 more
Caused by: java.lang.IllegalArgumentException: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.(GTDataStoreGranuleCatalog.java:207) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.catalog.GranuleCatalogFactory.createGranuleCatalog(GranuleCatalogFactory.java:145) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:586) [gt-imagemosaic-13.2-nn-1.jar:]
… 101 more
Caused by: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.extractBasicProperties(GTDataStoreGranuleCatalog.java:281) [gt-imagemosaic-13.2-nn-1.jar:]
at org.geotools.gce.imagemosaic.catalog.GTDataStoreGranuleCatalog.(GTDataStoreGranuleCatalog.java:192) [gt-imagemosaic-13.2-nn-1.jar:]
… 103 more
Thank You
Dominique Bessette
Sent: Monday, November 30, 2015 6:34 PM
To: Andrea Aime (andrea.aime@…1107…); geoserver-users@lists.sourceforge.net
Subject: FW: [Geoserver-users] GTDataStoreGranuleCatalog class error
Hi Andrea
I tried attaching the server.log but the email group rejected it. Trying again.
Our GeoServer version is 2.7.2. I’m storing the granules in a database. I viewed the database table called missionid2_coaid3_aoiid1_ruleid4_thresholdid23 and it looks like it was created and everything was stored correctly. What’s interesting is I can manually go into GeoServer and create the layer that failed.
Login to geoserver
Select Layers
Click Add New Resource
Select the workspace and store
I can see the Layer Name that failed. (screenshot attached)
Hit publish
Choose the correct styling in the Publishing tab
Enable Time dimension in the Dimensions tab
Select Save and the layer is now created. (see attached screenshot)
Sent: Saturday, November 14, 2015 5:13 AM
To: Bessette-Halsema, Dominique E
Subject: Re: [Geoserver-users] GTDataStoreGranuleCatalog class error
On Sat, Nov 14, 2015 at 1:20 AM, Bessette-Halsema, Dominique E <Dominique.Bessette@…1196…> wrote:
Hi
I’m using the image mosaic plugin and I get the following error from the GTDataStoreGranuleCatalog class intermittently.
BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource: java.io.IOException: BBOXFilterExtractor::extractBasicProperties(): unable to get a schema from the featureSource
Do you have the full stack trace?
What version of GeoServer is giving you these errors?
If I try to recreate the image mosaic overlay it’ll work fine. Do you have any idea why this would be happening?
My indexer.properties file contains the following
TimeAttribute = validtime
ElevationAttribute = elevation
Envelope2D = 119.00390624999999,0.3515625,129.00390625,10.3515625
Schema = *the_geom:Polygon,location:String,validtime:java.util.Date,elevation:Double
PropertyCollectors = TimestampFileNameExtractorSPItimeregex,DoubleFileNameExtractorSPIelevationregex
Where are you storing the collected granules? If it’s a database, can you share your datastore.properties?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
