Hello there
we also have had some problems upgrading a geoserver instance from 2.2 to 2.7
we copied the data dir from one to the other and everything worked except for the cached layers… they gave the error below: Current styles of layer not available
we saw that manually going to the layer in the web admin and clicking save fixed it.. and then looking in the (gwc) layer file in the config we see that a new section has been added:
<parameterFilters>
<styleParameterFilter>
<key>STYLES</key>
<defaultValue></defaultValue>
<availableStyles class="sorted-set"/>
<defaultStyle>raster</defaultStyle>
</styleParameterFilter>
</parameterFilters>
we then wrote a little python script to GET the layer xml to a file, then POST the same XML back, which appears to have simulated cliking save on each layer and it is mostly working now.. except for a different GWC bug which I will now write a different email for.
so get the list of layers using:
curl -u admin:xxxx "http:// localhost:8080/geoserver/gwc/rest/layers/"
# write XM to a file
curl -u admin: xxxx "http://localhost:8080/geoserver/gwc/rest/layers/workspace:layer.xml" > xml.xml
# post xml back to simulate save
curl -u admin: xxxx -XPOST -H "Content-type: text/xml" -d @xml.xml "http://localhost:8080/geoserver/gwc/rest/layers/workspace:layer.xml "
maybe this helps someone
-i
De : Kevin Smith [mailto:ksmith@anonymised.com]
Envoyé : mercredi 1 avril 2015 20:38
À : Andrea Aime
Cc : Johannes Engel; GeoServer Mailing List List
Objet : Re: [Geoserver-users] GWC 400: Current styles of layer not available
Sorry about taking so long to respond. I'd hoped to find some time to look into it in a bit of depth but I've been rather busy. I can't think of anything in particular that would cause this beyond, as Andrea said, the setLayer method not being called or the state of the filter being cleared after having been set. Figuring out why that's happening (or not happening) would require replicating it and doing some debugging.
On 26 March 2015 at 09:36, Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>> wrote:
On Thu, Mar 26, 2015 at 4:15 PM, Johannes Engel <johannes.engel@anonymised.com<mailto:johannes.engel@anonymised.com>> wrote:
after upgrade to GeoServer 2.7.0 (running under Tomcat
6.0.41-2+squeeze6, Oracle Java 1.7.0.76, Linux Debian 64bit) I have
problems with a layer that used to work with 2.6.2.
The layer is accessed using the global /gwc/service/gmaps Service.
Example:
http://<server>/geoserver/gwc/service/gmaps?layers=naturpark:v_np_border&zoom=9&x=267&y=178&format=image/png8
Shortly after a restart of Tomcat everything is working as expected.
After some time (30min) a status 400-Page (text/html) is returned:
400: Current styles of layer not available.
The error persists until the next server restart.
This is what is in the log for a failed request (DEBUG Logging):
2015-03-26 14:40:21,917 DEBUG [ows.OWSHandlerMapping] - Matching patterns for request [/gwc/service/gmaps] are [/gwc/service/**]
2015-03-26 14:40:21,917 DEBUG [ows.OWSHandlerMapping] - URI Template variables for request [/gwc/service/gmaps] are {}
2015-03-26 14:40:21,918 DEBUG [ows.OWSHandlerMapping] - Mapping [/gwc/service/gmaps] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
2015-03-26 14:40:21,928 ERROR [geowebcache.GeoWebCacheDispatcher] - Current styles of layer not available. http://<server>/geoserver/gwc/service/gmaps
2015-03-26 14:40:21,928 DEBUG [geowebcache.GeoWebCacheDispatcher] - Current styles of layer not available.
This is actually an exception throw by the StyleParameterFilter class, it seems the setLayer method
never got called... but I don't know why. Kevin, do you have any clue?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
mob: +39 339 8844549<tel:%2B39%20%C2%A0339%208844549>
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Kevin Smith
Software Engineer | Boundless<http://boundlessgeo.com/>
ksmith@anonymised.com<mailto:ksmith@anonymised.com>
+1-778-785-7459
@boundlessgeo<http://twitter.com/boundlessgeo/>
[Image supprimée par l'expéditeur. http://boundlessgeo.com/\]
BPM Camp - Free Virtual Workshop May 6th at 10am PDT/1PM EDT
Develop your own process in accordance with the BPMN 2 standard
Learn Process modeling best practices with Bonita BPM through live exercises
http://www.bonitasoft.com/be-part-of-it/events/bpm-camp-virtual- event?utm_
source=Sourceforge_BPM_Camp_5_6_15&utm_medium=email&utm_campaign=VA_SF
Geoserver-users mailing list
