GWC is not really aware of workspaces. It considers the whole prefixed name to be the name of the layer without any idea that it has two parts. There is presently no counterpart to GeoServer’s virtual services in GeoWebCache. So when using GWC you always have to give the full name of the layer.
On 18 February 2015 at 04:42, Sergey Kolosov <sergey.kolosof@anonymised.com> wrote:
Hello!
I’ve discovered strange behavior in GWC. If layer’s workspace is not provided in LAYERS param, the cache is not generated. Though tiles are coming on the client side. URLs to make it clear:
Tiles are coming, cache is not generated:
http://localhost:8080/geoserver/topp/gwc/service/wms?LAYERS=states&FORMAT=image/png&TILED=true&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3857&BBOX=-10331840.237812,4696291.0171875,-10018754.17,5009377.085&WIDTH=256&HEIGHT=256
Tiles are coming and cache is generated:
http://localhost:8080/geoserver/gwc/service/wms?LAYERS=topp:states&FORMAT=image/png&TILED=true&TRANSPARENT=TRUE&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:3857&BBOX=-10331840.237812,4696291.0171875,-10018754.17,5009377.085&WIDTH=256&HEIGHT=256
So cache generation is depending on where workspace is specified. It is the second problem I ran into when workspace is in the address rather than in the param (the first problem was about styles).
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Kevin Smith
Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
I thought if GWC can transfer the tile without workspace, it can put this tile in the cache too. But now I see the background. Thanks, Kevin!
2015-02-18 22:32 GMT+03:00 Kevin Smith <ksmith@anonymised.com>:
Hello!
Kevin Smith
+1-778-785-7459
@boundlessgeo
