[Geoserver-users] Gwc layers disappearing
Hi list,
I have deployed a 2.3.1 and sometimes, with no errors in the logs, the layers are removed from the gwc management and on the client I get 404’s I have to go back to the layer tile-caching tab and reactivate them.
Thanks for any suggestions you can give.
Simone
Dear all,
I can add that this problem occurs on GeoServer 2.3.1 running on Ubuntu,
Tomcat7 (Oracle 1.7.0_21 Java HotSpot(TM) 64-Bit Server VM) retrieving data
from PostGIS 2.0. We upgraded our application from GeoServer 2.1 running on
Ubuntu, Tomcat6 and PostGIS 1.5 and this problem does not occur with this
configuration.
This is the log file output:
2013-05-14 07:48:15,719 WARN [gwc.layer] - Can't compute bounds for tile
layer erds:forecast_alert_grid_h24 in CRS EPSG:900913. Assuming full GridSet
bounds. (null)
2013-05-14 07:48:15,733 WARN [gwc.layer] - Can't compute bounds for tile
layer erds:forecast_alert_grid_h24 in CRS EPSG:4326. Assuming full GridSet
bounds. (null)
2013-05-14 08:03:19,753 ERROR [geowebcache.GeoWebCacheDispatcher] - Thread
8346 Unknown layer erds:trmm_alert_geom. Check the logfiles, it may not have
loaded properly. http://localhost:8080/geoserver/gwc/service/wms
2013-05-14 08:04:08,806 WARN [gwc.layer] - Can't compute bounds for tile
bounds. (null)
2013-05-14 08:04:08,809 WARN [gwc.layer] - Can't compute bounds for tile
bounds. (null)
2013-05-14 08:06:50,700 WARN [config.CustomEditorConfigurer] - Passing
PropertyEditor instances into CustomEditorConfigurer is deprecated: use
PropertyEditorRegistrars or PropertyEditor class names instead. Offending
key [org.geotools.util.Version; offending editor instance:
org.geoserver.platform.util.VersionPropertyEditor@anonymised.com
Thank you so much for your help.
Bye
Paolo
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gwc-layers-disappearing-tp5052904p5053083.html
