Making it work with poor quality is better than nothing. What irritates me is that you could not make it work through image mosaic. However, without original images it is rather impossible for us to do anything more. You have already tried remotely all that we have been able to suggest.
Let's hope that some high enough officer from the OS is reading this list and has power to send me links to the two maps which are recognized to be enough for repeating the issue.
-Jukka Rahkonen-
Tom Chadwin wrote:
OK, that all seems to have worked - many thanks. I am going to try rerunning it,
though, as the image quality is not good enough. I'll see if Lanczos is available
on my install, or look at the other options.Any thoughts on the fact that the TIFF is bigger than the 2GB mentioned in the
docs as potentially problematic?Thanks again for all the help
Tom
View this message in context: http://osgeo-org.1560.x6.nabble.com/Error-
rendering-coverage-on-the-fast-path-tp5138864p5140164.html
Sent from the GeoServer - User mailing list archive at Nabble.com.------------------------------------------------------------------------------
"Accelerate Dev Cycles with Automated Cross-Browser Testing - For FREE
Instantly run your Selenium tests across 300+ browser/OS combos.
Get unparalleled scalability from the best Selenium testing platform available
Simple to use. Nothing to install. Get started now for free."
http://p.sf.net/sfu/SauceLabs
Geoserver-users mailing list
