[Geoserver-users] GWC seeding: Error rendering coverage on the fast path
I am using Geoserver 2.5 (release) installed from zip on Win-7 64-bit and a bit old jre 1.7.0_07(ORA) .
I managed to get errors also from the normal layer preview window by doing the following:
  • I created image mosaic topp:os from the two OS tiles
  • Clicked on layer preview
  • Zoomed till scale 1:35K
  • Panned the map to the East
  • Now I start seeing an empty map
  • Changing zoom level to 1:70K or 1:17K shows map in this location
  • Error at 1:35K is the java.lang.ArrayIndexOutOfBoundsException
I could repeat the java.lang.ArrayIndexOutOfBoundsException error also from browser with URL
http://localhost:8080/geoserver/topp/wms?BBOX=385000,487500,387500,490000&VERSION=1.1.1&FORMAT=image/jpeg&SERVICE=WMS&HEIGHT=256&LAYERS=topp:os&REQUEST=GetMap&STYLES=&SRS=EPSG:27700&WIDTH=256
The method I used to capture the previous error was to open the GWC demo window from http://localhost:8080/geoserver/gwc/demo/topp:os?gridSet=EPSG:4326&format=image/png
Screen captures from the layer preview and GWC demo attached.
-Jukka Rahkonen-
Andrea Aime wrote:
On Fri, May 16, 2014 at 10:37 AM, Rahkonen Jukka (Tike) <jukka.rahkonen@…486…> wrote:
Yes, I can repeat the error. At one certain zoom level requests to get some tiles always fail. The error at Geotools dev level is:
16 touko 11:25:35 ERROR [org.geowebcache.GeoWebCacheDispatcher] - Problem communicating with GeoServ
er http://localhost:8080/geoserver/gwc/service/wms
Here comes all that appears into the log when panning a bit at that zoom level. It is quite a lot, normal Geoserver users can stop reading here.
I’ve just tried using the development version, making both direct wms calls and gwc ones in 4326 and 900913, png and jpeg… I’m getting no errors.
Then I’ve tried with the current 2.5.x series, and again, nothing.
Looking at Jukka’s log I’ve reconstructed this GetMap which should apparently fail, but it does not for me, I just get a blank output:
http://localhost:8080/geoserver/wms?BBOX=-2.109375,54.140625,-1.93359375,54.4921875&SERVICE=WMS&HEIGHT=512&REQUEST=GetMap&STYLES=raster&WIDTH=256&EXCEPTIONS=SE_XML&TRANSPARENT=true&VERSION=1.1.1&FORMAT=image/png&GWC_SEED_INTERCEPT=true&LAYERS=mosaicError&SRS=EPSG:4326
I likely have lost something along the 50 messages in this thread.
Jukka, which version of GeoServer were you trying, using which JDK and so on?
Meet us at GEO Business 2014! in London! Visit http://goo.gl/fES3aK
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
