On Thu, Mar 26, 2015 at 11:25 AM, Tobias Reinicke <ramotswa@anonymised.com>
wrote:
Hi All,
I was wondering if it was possible to disable the special http response
headers that are sent back from GWC. In particular I don't really want GWC
to send back the tile bounds header (potential security issue).
Could you explain how the tile bounds can be seen as a security issue? It's
mere georeferencing... you're afraid that someone would intercept the
requests (e.g., man in the middle) and rebuild your original data?
geowebcache-tile-index: [64, 34, 6]
Content-Type: image/png
Content-Length: 2204
geowebcache-cache-result: HIT
geowebcache-tile-bounds: 0.0,5.625,2.8125,8.4375
geowebcache-gridset: EPSG:4326
geowebcache-crs: EPSG:4326
Last-Modified: Thu, 26 Mar 2015 10:37:31 GMT
Content-Disposition: inline; filename=geoserver-dispatch.image
That said, I don't know of a way to disable those headers, save changing
the code or setting up a proxy in the middle that removes the headers.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
