I 've created a web map viewer using OpenLayers, ExtJS, GeoExt and GXP. I've
added a LayerTree (gxp_layertree) that shows layers from various WMS servers
(GeoServers). I've also configured a FeatureManager (gxp_featuremanager)
with 'autoLoadFeatures = true' and a FeatureGrid (gxp_featuregrid).
The problem appears when I click on a layer tree node: the FeatureManager
doesn't "autoLoadFeatures", it just fires a DescribeLayer request to get the
column names for the FeatureGrid.
Trying to isolate the problem for a couple of hours by commenting and
changing code I've discovered it works perfectly with projection setted to
EPSG:4326, but not with EPSG:3857 or 900913.
Do you have any idea about why this is happening or how to solve it??
I need the map projection to be 3857 because I have Google base layers.
Thanks in advance.
Cristian.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GXP-FeatureManager-not-firing-WFS-requests-when-setting-EPSG-3857-900913-tp5086363.html
