[Geoserver-users] H2 for NETCDF: Exception opening port H2 TCP Server
Hi List,
I am working with geoserver 2.8.1 and netcdf stores and I get the following error.
The port numer change with each restart. I´m working with Ubuntu. I tested geoserver and netcdf plugin with windows and it worked fine, but not with ubuntu.
Are there any hints?
Thanks and regard,
Lotta
Caused by: org.geotools.data.DataSourceException: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
Exception opening port H2 TCP Server (tcp://localhost:46303) (port may be in use), cause: timeout [90061-119])
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:126)
at org.geotools.coverage.io.netcdf.NetCDFDriver.connect(NetCDFDriver.java:92)
at org.geotools.coverage.io.impl.DefaultFileDriver.process(DefaultFileDriver.java:216)
at org.geotools.coverage.io.netcdf.NetCDFReader.(NetCDFReader.java:156)
… 131 more
Caused by: java.lang.RuntimeException: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:266)
at javax.imageio.ImageReader.setInput(ImageReader.java:380)
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:115)
… 134 more
Caused by: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.geotools.imageio.netcdf.NetCDFImageReader.initIndex(NetCDFImageReader.java:365)
at org.geotools.imageio.netcdf.NetCDFImageReader.init(NetCDFImageReader.java:472)
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:264)
… 136 more
Caused by: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.(CoverageSlicesCatalog.java:231)
at org.geotools.imageio.GeoSpatialImageReader.initCatalog(GeoSpatialImageReader.java:205)
at org.geotools.imageio.netcdf.NetCDFImageReader.initIndex(NetCDFImageReader.java:285)
… 138 more
Caused by: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1829)
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:949)
at org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:308)
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.(CoverageSlicesCatalog.java:202)
… 140 more
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:48)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1814)
… 143 more
Caused by: org.h2.jdbc.JdbcSQLException: Fehler beim Öffnen von Port H2 TCP Server (tcp://localhost:46303) (Port wird ev. bereits verwendet), Grund: timeout
at org.h2.message.Message.getSQLException(Message.java:106)
at org.h2.message.Message.getSQLException(Message.java:117)
at org.h2.tools.Server.start(Server.java:361)
at org.h2.engine.Database.startServer(Database.java:708)
at org.h2.engine.Database.open(Database.java:584)
at org.h2.engine.Database.openDatabase(Database.java:222)
at org.h2.engine.Database.(Database.java:216)
at org.h2.engine.Engine.openSession(Engine.java:58)
at org.h2.engine.Engine.openSession(Engine.java:140)
at org.h2.engine.Engine.getSession(Engine.java:120)
at org.h2.engine.SessionFactoryEmbedded.createSession(SessionFactoryEmbedded.java:17)
at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:245)
at org.h2.engine.SessionRemote.createSession(SessionRemote.java:223)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:110)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:94)
at org.h2.Driver.connect(Driver.java:58)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
… 147 more
this is unusual, we have multiple installation on linux that are not exhibiting this problem (but I don’t
think we have production instances on Ubuntu).
Wondering if you have it setup with extra security, disallowing opening TCP ports at all?
Normally ports above 1000 are fair game.
The error trought google translate is:
“Error opening port H2 TCP Server (tcp: // localhost: 46303) (. Port is possibly already in use), reason: Timeout”
Hum… possibly already in use… that is also strange thought, H2 server should be trying to open a random
port.
I’m cc’ing Daniele above, Daniele, I was wondering, any way to make H2 not start in server mode?
I guess that’s useful for debugging, not sure if needed for actual production (let us know if it is).
On Thu, Feb 4, 2016 at 12:13 PM, axxis l <axxis1980@anonymised.com> wrote:
Hi List,
Thanks and regard,
Lotta
… 131 more
… 134 more
… 136 more
… 138 more
… 140 more
… 143 more
… 147 more
Site24x7 APM Insight: Get Deep Visibility into Application Performance
APM + Mobile APM + RUM: Monitor 3 App instances at just $35/Month
Monitor end-to-end web transactions and take corrective actions now
Troubleshoot faster and improve end-user experience. Signup Now!
http://pubads.g.doubleclick.net/gampad/clk?id=272487151&iu=/4140
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Taking a look at the code and looking on the JIRA history, I have found GEOT-4533 which has been fixed by forcing the Automatic mixed mode1 to be set as default connection parameter:
https://github.com/geotools/geotools/blob/master/modules/plugin/jdbc/jdbc-h2/src/main/java/org/geotools/data/h2/H2DataStoreFactory.java#L168
https://github.com/geotools/geotools/blob/master/modules/plugin/jdbc/jdbc-h2/src/main/java/org/geotools/data/h2/H2DataStoreFactory.java#L180
The server mode allows for easier development and debug/querying of the H2 DB content/status.
A thing we can do is opening a JIRA to make this parameter configurable through a System property
Does it make sense?
Daniele
On Fri, Feb 5, 2016 at 8:22 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
port.
Hi List,
Thanks and regard,
Lotta
… 131 more
… 134 more
… 136 more
… 138 more
… 140 more
… 143 more
… 147 more
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
Hi, I got the same error
create PoolableConnectionFactory (Exception opening port H2 TCP Server
(tcp://localhost:59575) (port may be in use), cause: timeout [90061-119])
I am using a VM CentoOS6, geoserver 2.8.3. Just wondering if you have found
a solution to this problem? (Selinux and iptables disabled)
View this message in context: http://osgeo-org.1560.x6.nabble.com/H2-for-NETCDF-Exception-opening-port-H2-TCP-Server-tp5248863p5268879.html
