[Geoserver-users] H2 for NETCDF stores suddenly no longer functional : Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119]
All,
I am working with the latest version of geoserver and have been having pretty good success with NETCDF stores and image mosaics backed by NETCDF – until last week. All of a sudden, any operation involving NETCDF stores results in the following error. The port number seems to change with each restart, and prior to startup the port number it says is in use is NOT in use, so it is geoserver itself which is using the port. I am hosting my server in amazon EC2 and some security updates were recently applied, but I am can imagine why that would have an impact on localhost tcp connections. Any advice would be greatly appreciated.
04 Jan 18:07:41 WARN [netcdf.NetCDFFormat] - Unable to connect
org.geotools.data.DataSourceException: Unable to connect
at org.geotools.coverage.io.netcdf.NetCDFReader.(NetCDFReader.java:159)
at org.geotools.coverage.io.netcdf.NetCDFFormat.getReader(NetCDFFormat.java:95)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1441)
Caused by: org.geotools.data.DataSourceException: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:126)
at org.geotools.coverage.io.netcdf.NetCDFDriver.connect(NetCDFDriver.java:92)
at org.geotools.coverage.io.impl.DefaultFileDriver.process(DefaultFileDriver.java:216)
at org.geotools.coverage.io.netcdf.NetCDFReader.(NetCDFReader.java:157)
… 123 more
Caused by: java.lang.RuntimeException: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:266)
at javax.imageio.ImageReader.setInput(ImageReader.java:380)
at org.geotools.coverage.io.netcdf.NetCDFAccess.(NetCDFAccess.java:115)
… 126 more
Caused by: java.io.IOException: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.geotools.imageio.netcdf.NetCDFImageReader.initIndex(NetCDFImageReader.java:365)
at org.geotools.imageio.netcdf.NetCDFImageReader.init(NetCDFImageReader.java:472)
at org.geotools.imageio.netcdf.NetCDFImageReader.setInput(NetCDFImageReader.java:264)
… 128 more
Caused by: java.lang.IllegalArgumentException: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.(CoverageSlicesCatalog.java:231)
at org.geotools.imageio.GeoSpatialImageReader.initCatalog(GeoSpatialImageReader.java:205)
at org.geotools.imageio.netcdf.NetCDFImageReader.initIndex(NetCDFImageReader.java:285)
… 130 more
Caused by: java.lang.RuntimeException: Unable to obtain connection: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1986)
at org.geotools.jdbc.JDBCDataStore.createTypeNames(JDBCDataStore.java:976)
at org.geotools.data.store.ContentDataStore.getTypeNames(ContentDataStore.java:308)
at org.geotools.coverage.io.catalog.CoverageSlicesCatalog.(CoverageSlicesCatalog.java:202)
… 132 more
Caused by: org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119])
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at org.geotools.data.jdbc.datasource.AbstractManageableDataSource.getConnection(AbstractManageableDataSource.java:48)
at org.geotools.jdbc.JDBCDataStore.createConnection(JDBCDataStore.java:1971)
… 135 more
Caused by: org.h2.jdbc.JdbcSQLException: Exception opening port H2 TCP Server (tcp://localhost:50683) (port may be in use), cause: timeout [90061-119]
at org.h2.message.Message.getSQLException(Message.java:106)
at org.h2.message.Message.getSQLException(Message.java:117)
at org.h2.tools.Server.start(Server.java:361)
at org.h2.engine.Database.startServer(Database.java:708)
at org.h2.engine.Database.open(Database.java:584)
at org.h2.engine.Database.openDatabase(Database.java:222)
at org.h2.engine.Database.(Database.java:216)
at org.h2.engine.Engine.openSession(Engine.java:58)
at org.h2.engine.Engine.openSession(Engine.java:140)
at org.h2.engine.Engine.getSession(Engine.java:120)
at org.h2.engine.SessionFactoryEmbedded.createSession(SessionFactoryEmbedded.java:17)
at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:245)
at org.h2.engine.SessionRemote.createSession(SessionRemote.java:223)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:110)
at org.h2.jdbc.JdbcConnection.(JdbcConnection.java:94)
at org.h2.Driver.connect(Driver.java:58)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.commons.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
… 139 more
Steve Ferguson
Hi Steve,
I’ll take a look at the code you mentioned in your logs.
Is there any way to replicate the problem so I can do some debug?
Do you also have a chance to repeat your test with higher logging level?
Please, let us know.
Best Regards,
Daniele
On Mon, Jan 4, 2016 at 8:03 PM, Ferguson, Steve -FS <sferguson@anonymised.com> wrote:
All,
… 123 more
… 126 more
… 128 more
… 130 more
… 132 more
… 135 more
… 139 more
Steve Ferguson
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
Daniele,
I was able to resolve this, it turned out to be an issue with amazon EC2 not properly setting the hostname of my virtual instance. Even though H2 was configured with localhost, since the hostname of my EC2 instance could not be resolved, all H2 connections would timeout and fail. Fixing the hostname issue made H2 and the rest of Geoserver work again.
Steve
Hi Steve,
Best Regards,
Daniele
On Mon, Jan 4, 2016 at 8:03 PM, Ferguson, Steve -FS <sferguson@…102…> wrote:
All,
… 123 more
… 126 more
… 128 more
… 130 more
… 132 more
… 135 more
… 139 more
Steve Ferguson
