On Wed, Mar 18, 2015 at 11:56 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Random troubles (not sure if these are a bug to report or user error):
- Setting transparency color to #000000 fails to render (error rendering coverage on the fast path). I assume this works for RGB image and I am getting in trouble for combining #0000000 (with a byte for each band) and my original data that has a float.
Error rendering coverage on the fast path
java.lang.IllegalStateException: Unsupported data type.
Details:
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:338)
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
Jody Garnett
On 18 March 2015 at 15:55, Jody Garnett <jody.garnett@anonymised.com> wrote:
I got myself in a tangle today working with LandSat 5 data - I know this should be the easiest thing in the world right?
RasterSymbolizer lets you select a number of channels (4,5,1 generally match with RGB for a “true color” image). But here is where I run into trouble - the data is in the range 0.0 to 1.1 (with -Infinite as NO_DATA). I had hoped that setting this up in the geoserver layer definition, and then using SLD to select out the bands would magically work.
Ran into a couple problems:
- In the resulting visual NO_DATA is not respected as transparent … tried also in a layer group
- I was not sure I need to transform the data from each band (remember 0.0 - 1.0 float) to 0 to 256. We cannot do a colormap entry on each band … so I am a bit stuck.
Exploring the problem with a single band (and color map) we can map no data to a transparent color just fine - but this does not get me a full color image
Having a look at geometry transformations to see if we can stage a decent RGB channel before letting SLD have a crack at it:
- BandMerge lets me combine several bands into a resolution image
- Reclassify could be used to remap the 0.0f to 1.0f range to 0 to 256 integers expected by SLD
Putting these two ideas together (as a geometry transformation) may work - but I wanted to check before proceeding.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
