[Geoserver-users] hardcoded schemalocation in wfs response
If i make a DescribeFeatureType request, in the response, i will have hardcoded value for the schemaLocation of wfs 2.0
<xsd:import namespace=“http://www.opengis.net/wfs/2.0” schemaLocation=“jar:file:/home/fgravin/.m2/repository/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/gt-xsd-wfs-9-SNAPSHOT.jar!/org/geotools/wfs/v2_0/wfs.xsd”/>
I would like it to be something like http://schemas.opengis.net/wfs/2.0/wfs.xsd
How could i proceed ?
Thks
Florent Gravin
Camptocamp - Chambéry
0479444492
Florent,
what GeoServer version are you using? Is this an app-schema type? If so, what is your schemaUri?
Why would you want any sort of WFS import in a WFS DescribeFeatureType response? The response should be a XSD document, and unless your feature types are defined in terms of WFS (which I would find very strange), there should be no use of the WFS schema in the payload information model.
Clients should never see classpath JAR file references.
Kind regards,
Ben.
On 14/12/12 22:16, Florent Gravin wrote:
<xsd:importnamespace="http://www.opengis.net/wfs/2.0&quot;schemaLocation=&quot;jar:file:/home/fgravin/\.m2/repository/org/geotools/xsd/gt\-xsd\-wfs/9\-SNAPSHOT/gt\-xsd\-wfs\-9\-SNAPSHOT\.jar\!/org/geotools/wfs/v2\_0/wfs\.xsd&quot;/&gt;
Thks
Florent Gravin
0479444492
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hi Ben, thanks for your reply.
I’m using Geoserver master branch, and yes it is an app-schema type.
My schema uri is http://inspire.ec.europa.eu/schemas/au/3.0/AdministrativeUnits.xsd (urn:x-inspire:specification:gmlas:AdministrativeUnits:3.0).
I don’t really want to have this import, but it is there i haven’t customized any thing to get this i guess.
Maybe i could try to remove it but i don’t know how to process.
thanks for help
On Mon, Dec 17, 2012 at 4:03 AM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Florent,
Kind regards,
Ben.
xsd:importnamespace="[http://www.opengis.net/wfs/2.0](http://www.opengis.net/wfs/2.0)"schemaLocation=“jar:file:/home/fgravin/.m2/repository/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/gt-xsd-wfs-9-SNAPSHOT.jar!/org/geotools/wfs/v2_0/wfs.xsd”/
Thks
Florent Gravin
0479444492
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Florent Gravin
0479444492
Well there is some code in https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/xml/FeatureTypeSchemaBuilder.java#L369
that add the wfs schema and put a jar url for wfs.xsd
We made a hack for this but i think geoserver team should have a look about this issue.
On Wed, Jan 2, 2013 at 11:44 AM, Florent Gravin <florent.gravin@anonymised.com> wrote:
thanks for help
Florent,
Kind regards,
Ben.
Thks
Florent Gravin
0479444492
Software Engineer
Florent Gravin
0479444492
Florent Gravin
0479444492
On Wed, Jan 9, 2013 at 11:50 AM, Florent Gravin <florent.gravin@anonymised.com.1104…> wrote:
Please open a bug report and attach your patch.
Also, remember that WFS 2.0 + app schema is not an officially supported combination as far as I know,
in particular, app-schema does not work well with GML 3.2 I believe.
It may take some time to get confirmation, app-schema is developed in Australia and it’s vacation time
over there now.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
All reports I have are that app-schema works with GML 3.2 (I rewrote the GeoTools GML 3.2 bindings so that it did). There are production deployments using it for GeoSciML 3 and WaterML 2.
Very little of WFS 2.0 that is not in WFS 1.1 is supported. Paging will fail silently. resolveDepth is not supported. WFS 1.1 with outputformat=gml32 works well. There are namespace prefix gotchas with known workarounds.
Australia and it's vacation time
over there now.
Too ... hot ... to ... work ...
http://www.watoday.com.au/wa-news/new-year-brings-end-to-perths-record-heatwave-20130101-2c3q8.html
http://www.australiangeographic.com.au/journal/australias-heatwave-a-taste-of-things-to-come-tim-flannery.htm
Software Engineer
<florent.gravin@anonymised.com <mailto:florent.gravin@anonymised.com>>
Florent, I wrote that method, and I am aware that it is fragile and relies on observed behaviour of the EMF libraries, rather than reason, which does not seem to apply. A patch that fixes this problem would be welcome. A unit test would be great. Can you reproduce the problem using an existing test fixture? As I said, no response should contain a jar URL.
Kind regards,
Software Engineer
