[Geoserver-users] Hardware Requirements for WMS Server
Hello all,
Are there any suggestions/experiences on hardware configuration for a fast Geoserver production environment. Where are the bottlenecks? CPU, RAM, DISK, Operating System?
Second question: Did you also experience performance issus when loading a geoserver WMS into ArcGIS (9.2). Our Geoserver WMS is fast in a browser client, but when loaded into ArcGIS its 2-5 times slower. This effect is not visible with a UMN Mapserver WMS. Any suggestion on that?
André
On Fri, Aug 22, 2008 at 2:23 PM, Müller, André
<Andre.mueller@anonymised.com> wrote:
Hello all,
Operating System?
As far as I know ArcGIS 9.2 does not like the looooooong list of CRS
that GeoServer spits out in its XML responses.
Ciao,
Simone.
André
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great
prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-users mailing list
Eng. Simone Giannecchini
President /CEO GeoSolutions S.A.S.
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
Hello all,
Operating System?
Btw, this can be prevented by setting a custom list of EPSG codes in
Config/WMS/Content (comma separated list of values).
Müller ha scritto:
Hello all,
In my experience you need enough RAM to avoid swapping (2GB are usually
more than enough to keep GeoServer, a spatial database server and leave
quite some room for the FS cache), and then your need fast CPU, latest
JDK, and a fast disk if you're going to serve lots of data (way more
than what can possibly be fit in the fs cache).
In the case of "lots of data" spatial dbms tuning is also very
important.
Operating system wise, I don't know, we use a variety of Linux
based operating systems, haven't noticed particular differences
between them.
