[Geoserver-users] hatch rendering (long)
hello all,
i am trying to use GeoServer 1.5.1 with a user-style using hatches and i
noticed a strange behaviour which at this point looks likely to be a
bug --but i could be wrong-- and would appreciate confirmation.
i have attached a simple SLD which uses two hatch (PNG) files (also attached)
to facilitate reproducing the case.
the second hatch (hatchB) does not get rendered correctly --it looks like it's
rotated 90-deg. changing the Rotation element in one or both GraphicFill and
Fill elements does not seem to affect the outcome.
am i doing something wrong, or is this a bug i should file?
TIA + cheers;
rsn
ps. the URL to reproduce (with appropriate change to suit your environment is:
http://localhost:8080/geoserver/wms?SERVICE=WMS&FORMAT=image/png&HEIGHT=480&SLD=http%3A%2F%2Fsolomon%3A9090%2Fmi-bug.sld&BGCOLOR=0xFFFFFF&REQUEST=GetMap&WIDTH=640&BBOX=-122.40632920964042,47.51843407712561,-122.06545788004654,47.77408757432104&SRS=EPSG:4326&VERSION=1.1.1
mi-bug.sld (8.31 KB)
