[Geoserver-users] Having trouble to Parameterizing SQL Views in Geoserver
First, I have a table with the next values:
Name Table: 10-0, Values: id, clave_radial, date_time, the_geom
I have the following SQL View:
SELECT * FROM "10-0" WHERE date_time BETWEEN
%firstDatetime% AND %secondDatetime%
And I’m always getting the same error:
SQL: ERROR: syntax error at or near "AND" Position: 63
What am I doing bad? Really I don’t understand…
By the way, The regular expression to validate the datetimes is:
^(\d{4})-(\d{2})-(\d{2}) (\d{2}):(\d{2}):(\d{2})$
Estudiante de Ingeniería Civil en Computación,
Universidad de Talca.
On Mon, Aug 17, 2015 at 10:30 PM, Javier Muñoz <jamunzv@anonymised.com> wrote:
And I'm always getting the same error:
When are you getting this error? Trying to list the attributes in the view?
In this case normally it's because you did not provide suitable default
values
for the firstDateTime and secondDateTime parameters
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
