[Geoserver-users] Heatmap rendering with fixed BBOX
Hi list,
does anyone know if there is a possibility to render a heatmap for a
fixed BBOX of the underlying dataset?
To be more concrete: I have a set of point geometries for which I want
to have heatmap and expose this as WMS. I want to ensure that the
heatmap is rendered based on the points within a fixed BBOX and not the
BBOX of the WMS request. At least it looked to me like GeoServer heatmap
rendering transformation is taking the WMS Request BBOX as a calculation
base.
Thanks in advance for any hint / help
Chris
The best plan is to import your data into QGIS and use the heat map plugin there to produce a new raster layer, then import that into GeoServer.
Ian
ยทยทยท
Ian Turton
Christian,
depending on your data source you could define a sql query with a fixed
bbox.
Sent from: http://osgeo-org.1560.x6.nabble.com/GeoServer-User-f3786390.html
Hi Chris,
One approach is to render the heatmap at a suitable resolution and then save the result as a format that GeoServer can render (such as GeoTiff). That GeoTiff can be registered as a new layer, and you can serve up that layer. Users/clients would be able to zoom around that layer and set a consistent picture (e.g., without local scaling).
I was involved in a project where we let users make such a query in an ad hoc manner and then we saved the GeoTiff using a custom WPS (that did some of the underlying wiring).
Alternatively, you could re-write the DensityProcess slightly to work slightly differently.
I believe your use case would require some external tools or some code changes. (That said, maybe I'm missing something clever!)
Jim
On 5/19/2020 8:53 AM, Christian Mayer wrote:
Hi list,
base.
Chris
Geoserver-users mailing list
Please make sure you read the following two resources before posting to this list:
- Earning your support instead of buying it, but Ian Turton: http://www.ianturton.com/talks/foss4g.html#/
- The GeoServer user list posting guidelines: http://geoserver.org/comm/userlist-guidelines.html
If you want to request a feature or an improvement, also see this: https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Hi Ian, Olivier and Jim,
thank you very much for your help by sharing your thoughts on this.
So it seems it needs some external (pre-)processing or adaption of code. For me it seems that preprocessing by an external tool is the more suitable way. I'll dig a bit into this and report back here once I have a running solution.
Thanks again
Chris
Am 19.05.20 um 19:10 schrieb Jim Hughes:
Hi Chris,
Jim
Hi list,
base.
Chris
to this list:
to this list:
